Transmission Trouble...
Old Mar 3, 2008 | 05:03 PM
SCCar_guy's Avatar
SCCar_guy
Default Transmission Trouble...
I am having kind of an odd problem with my 05 z51 mn6 when going from 5th to 6th. when i initially shift to 6th after releasing the clutch it pops out of gear. Once i shift it back into 6th it stays and runs fine. it only does this in 6th gear. I did search but did not find ayone else complaining of this problem. at first i thought it error on my part, releasing the clutch to soon or something. but i drove the car around a bunch over the weekend ensuring that i was shifting correctly and it still this. So if any of you have a clue please let me know.
thanks in advance
bill
Old Mar 3, 2008 | 06:26 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
interesting issue. not synchro-related. have you been to the dealer? is your car still under warranty?
Old Mar 3, 2008 | 07:04 PM
SCCar_guy's Avatar
SCCar_guy
no i have not yet taken it to the dealer, and unfortunatly it is just over its warrenty, the car only has about 20000 miles on though. I just figuered i would see if anyone here had delt with this issue first.
Old Mar 3, 2008 | 08:16 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
in a way, I hope no one else has had the issue. may I suggest if it is very close to the end of warranty, don't drive it to rack up more miles. and try and see if they'll still honor it as a warranty, or very recent warranty issue, if that becomes necessary?
it could be just a change of trans fluid, but I doubt it. hhmmm, have you pm'ed ranger or shopdog? could be they may've heard about this before. how about "chevy tech"?
Old Mar 3, 2008 | 09:24 PM
SCCar_guy's Avatar
SCCar_guy
not yet but i will, thanks for the advice
Old Mar 3, 2008 | 09:45 PM
SSPerformance's Avatar
SSPerformance
Sounds to me like you have a speed gear starting to go.....partially rounding which will cause that pop out.....also premature dog ring failure....or even the synchros premature failure.....could be afew things....Those are still T56 trans right?
Old Apr 17, 2008 | 01:45 AM
c6cbeyond's Avatar
c6cbeyond
Default Mine does the same thing.
I just took mine to the dealer, but I didnt say anything about it cause I thought it was my short shifter being lose cause it is kinda lose, but I think it might be a tranny problem. I just bought a three 36,000 mile extended warr. to make sure the tranny is still covered. I told them about my cam and others small modes but they said if the tranny brakes they would cover it. I do power shift my car alot and my friend has a gto and when his tranny went out 6th gear was the first to give him problems when shifting so let me know what happens with your. I have 25,580 miles.
Old Apr 17, 2008 | 01:53 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
If its popping out of gear, something major is amiss.
Old Apr 17, 2008 | 02:00 AM
KMK454's Avatar
KMK454
Not to, uh, dampen your spirits, but...
Mine did exactly what you're talking about once my car hit ~60k miles. It also had an occassional slight "grind" on the 1-2, and sometimes reverse was hard to find.
Here's what finally happened at 69k miles:
Turns out the root cause of it all was a bad throw-out bearing, an easy and relatively inexpensive fix versus a built T56, which is what I ended up having to do.
My advice would be to check it out with a trusted transmission mechanic ASAP. Small transmission glitches can snowball fast.
Old Apr 17, 2008 | 02:01 AM
c6cbeyond's Avatar
c6cbeyond
Default Mine just will not go into gear.
When I first shift it into gear it feels like its in gear but then its just not. So then i try again and it goes in fine.
Old Apr 17, 2008 | 02:26 AM
'06 Quicksilver Z06
I hate to be the bearer of bad news, but they might give you some $#** about your warranty and that short throw shifter.
http://forums.corvetteforum.com/show....php?t=1893750
To Transmission Trouble...
