Best octane booster currently ?
Old Mar 4, 2008 | 08:10 AM
REVAK's Avatar
REVAK
Default Best octane booster currently ?
Since the 94 octane went away locally, I have had to back up the timing a couple of degrees, any recommendations on what to spike 93 with for a 94 or 95 octane mix ? Thanks in advance.......
Old Mar 4, 2008 | 08:42 AM
rws.1's Avatar
rws.1
Xylene... Octane rating 117.
It is what refiners use along with Toluene and Benzene and Ethanol to blend gasoline base stock.
You can buy it a Home Depot by the gallon or at a paint store . A paint store that supplies commercial painters will also have it in 5 gallons metal cans.
European gasoline uses much higher aromatic content (approaching 30%) than American gas (~10%)
DISCLAIMER: Do an internet search on increasing octane and satisy yourself that it is safe for you and your car before you try it.
http://en.wikipedia.org/wiki/Xylene
http://www.offroaders.com/tech/octane.htm
http://www.gnttype.org/techarea/misc/octanebooster.html
Octane is a weighted average calculation
(#gallons * X octane + # gallons * Y octane)/ total gallons
Two examples...
(19* 93 + 1*117)/20 = 94.2
(18.5*93 + 1.5*117)/20= 94.8
Old Mar 4, 2008 | 09:21 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Raising your octane 1 octane point isnt going to do anything but waste your money.
If you had 94 and you now have 93 you shouldnt realize any real effect on the amount of timing you can run...certainly not to the point that you have to pull a couple degrees out.
Old Mar 4, 2008 | 10:01 AM
robz's Avatar
robz
Ib4jb
Old Mar 4, 2008 | 10:03 AM
CodyC6's Avatar
CodyC6
Originally Posted by robz
Ib4jb
Old Mar 4, 2008 | 10:12 AM
tcrcuda5's Avatar
tcrcuda5
at least u can get 93. only can get 91 in cali.
Old Mar 4, 2008 | 10:47 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Ib4jb
Old Mar 4, 2008 | 10:48 AM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
Torco baby!! It sure works for me, and many others!
JB
www.jbsblownc5.net
Old Mar 4, 2008 | 12:19 PM
SoldSyclone's Avatar
SoldSyclone
Have you tested Xylene or Torco?
I had 5 gallons of 92 in my car scan tool shows a little knock, added a half gallon of xylene and no more knock
I guess thats 2 octane points but proof it works.
(92*5) + (.5 Xylene 116) / 5.5 = 94
Old Mar 4, 2008 | 12:34 PM
11secondGP's Avatar
11secondGP
Ive tried both and they do both work well but I think TORCO is a little safer on the seals than Xylene.
To Best octane booster currently ?
