Socket for lugs?
Old Mar 7, 2008 | 02:46 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by AU N EGL
Heck I use an Impact wrench all the time. to about 85 lbs/ft then manual up to 100 lb/ft then torque wrench to 100 lb ft
dealers / tire shops use impact wrenches too.
It is just a lug nut, an aluminum beauty covered piece of steel.
Yea but if you use an impact a bunch of times on those stock lugs, they won't last long even with the fancy sockets....mine are all trashed. But I understand GM's basis for using them, those plastic beauty covers they used on C5's were expensive when you figured out how many they needed to buy!
Old Mar 7, 2008 | 03:43 PM
pimpinvcu's Avatar
pimpinvcu
Originally Posted by siffert
Damn thing looks like a shotgun shell!
Old Mar 7, 2008 | 04:14 PM
siffert's Avatar
siffert
I can confirm my Harbor Freight Electric Impact Wrench with nylon
protected socket trashed my oem lugs on the first try. I returned it
and now do it all manually via breaker bar, speed handle and torque
wrench. I can also confirm you can now say " I told you so" :o
Old Mar 7, 2008 | 04:43 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I would never do that. But next time I post this information perhaps you'll chime in to "second that motion".
Old Apr 8, 2009 | 09:09 AM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
OEM lug nuts? No way - get a set of GOOD lug nuts, or a set of 20 matching locks.
I use a pneumatic impact wrench all the time, with my 20 Gorilla locks, but I use it with a 95 lb.-ft torque stick, followed by a torque wrench set to 100 lb.-ft for the final. The torque stick does leave them about 1/16 of a turn loose for the final torque wrench snug-up.
To prove a point for a lawsuit, I once torqued the lug nuts on one rear wheel of my diesel pickup truck to just 40 lb.-ft, marked the orientation for frequent checking, then drove it for 4000 miles with nary a RCH (or is that an RCH) of movement. Factor of safety .
Old Apr 8, 2009 | 10:41 AM
GotChrist?'s Avatar
GotChrist?
NAPA has a set of inserts.
Item#: SPC35611
Price: $7.29
tax and shipping not included
Attributes:
Product Features:Protects Plated
Painted
or Capped Lug Nuts From Damage. Socket Inserts Fit Most Standard Lug Wrenches and Impact Sockets. Socket Inserts Require a 1/16" Hex Size Larger Socket Than The Lug Nut's H
Lug Sizes:7/8"
11/16"
3/4"
13/16"
Material:Plastic
Additional Contents:4 Socket Inserts
