Sirius SIR-GM1 install problems
Old Mar 5, 2008 | 06:44 AM
Nosgasman's Avatar
Nosgasman
Cruising
Default Sirius SIR-GM1 install problems
I recently installed a SIR-GM1 into my 05 w/ 6 disc changer radio without navigation. I have tried both the supplied T-harness and the factory xm radio harness in the rear of the vehicle. I am pressing the BAND button on the radio to cycle through available inputs, still nothing. Am I doing anything wrong?
Old Mar 5, 2008 | 04:41 PM
DEagle's Avatar
DEagle
Did your car come with XM originally? I'm not sure if the SIR-GM1 works on non-XM 05's. If you did have XM, then you will still see "XM1" and "XM2" displayed on the head unit as you toggle through the bands, but you will be listening to Sirius.
Old Mar 5, 2008 | 09:29 PM
Nosgasman's Avatar
Nosgasman
Cruising
My car did not come with XM, but does have the connection in the trunk.....
Old Mar 5, 2008 | 09:39 PM
wormie's Avatar
wormie
if it did not come with xm.does it have the antennea or did you add that too.(just a thought)
Old Mar 6, 2008 | 06:24 AM
Nosgasman's Avatar
Nosgasman
Cruising
I used the supplied Sirius antenna during the install. I didnt see any factory XM antenna installed in the car.
Old Mar 6, 2008 | 03:48 PM
DEagle's Avatar
DEagle
I think that's just because GM wanted to save money by using the same wire harness for every car.
If your car did not come with XM, then I think your head unit is not programmed to recognize the incoming signal. I'm not 100% sure of this - maybe one of the audio gurus on the board can back up my story...
Old Mar 6, 2008 | 04:09 PM
Nosgasman's Avatar
Nosgasman
Cruising
Makes sense. Has anyone had any luck using the supplied T-harness to plug into the back of the radio as instructed by the Sirius installation manual? I tried it but could not get it to work either.
Old Mar 6, 2008 | 06:52 PM
GentleBen's Avatar
GentleBen
Cruise-In 7-8-9-10-11-12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I can't speak to adding a Sirius radio to a '05 but I did add an XM module to my '05. The one thing you haven't mentioned is having the Body Control Module (BCM) reprogrammed to inform it that the additional radio component is present. Without this, the radio will not ever see the two XM bands where your Sirius receiver is. Your dealer, or anyone else with a Tech II device, can do this for you.
Old Mar 6, 2008 | 07:11 PM
Nosgasman's Avatar
Nosgasman
Cruising
I will check on this, Thank you.
Old Jul 19, 2010 | 01:34 PM
dub squared's Avatar
dub squared
Did you ever have any luck with this? I'm having the same problem now. Thanks for any info.
Old Jul 19, 2010 | 03:23 PM
Justasheet's Avatar
Justasheet
I'm pretty sure that you need a xm head (stereo) unit too.
Jeff
To Sirius SIR-GM1 install problems
