Cleaning a Callaway air filter
Old Mar 6, 2008 | 03:14 PM
Mag-Red's Avatar
Mag-Red
Default Cleaning a Callaway air filter
Does anyone know if I can use the K&N recharger kit to clean and oil the Callaway air filter? I have a unused kit from my last car and I was wondering if I should use it or toss it.
Old Mar 6, 2008 | 03:36 PM
Wayne88's Avatar
Wayne88
My Callaway Honker came with a K&N filter.
I think the earlier ones had a green colored filter.
Old Mar 6, 2008 | 06:53 PM
knkali's Avatar
knkali
not if it is a green filter
Old Mar 6, 2008 | 07:34 PM
GMRULZ's Avatar
GMRULZ
Per Corvette`s of Houston the K&N filter cleaner/charger kit may be used on the green filter. I called them since they sell it and I bought mine from their. I specified I had the green filter not the K&N.
Old Mar 6, 2008 | 07:51 PM
siffert's Avatar
siffert
The Green Filter is made by, you guessed it, the Green Filter Company.
I dont know or care what Corvette of Houston says, but you should only use GREEN FILTER CO. cleaner and green colored oil (not clear) on that Green Filter Co. filter of yours.
Not only that, you void the warranty on it as well. In fact, last time I checked, the Callaway Web site sells both the Green Filter kit and K&N Kit. (Callaway switched from the Green Filter Co. filters to the K&N about a year ago). Why would they do that if the K&N kit would do for both? Try calling the Green Filter Company tech support, they'll tell you the same thing.
Old Mar 6, 2008 | 08:11 PM
knkali's Avatar
knkali
if the green filter starts to fall apart from using the wrong cleaner---no good.
Old Mar 6, 2008 | 08:23 PM
LS1LT1's Avatar
LS1LT1
Don't toss it, send it to me.
Old Mar 6, 2008 | 08:38 PM
siffert's Avatar
siffert
Hmmm...I just realized Vararam has the same good taste in filters!
FYI, my Xcelerator CAI (Calllaway Honker clone) now uses a Green Filter Co. WHITE filter. They used to be green. So I would use Green Filter Co. cleaner and clear oil. So far, mine is clean as a whistle after 7K miles.
Old Mar 6, 2008 | 10:18 PM
Mag-Red's Avatar
Mag-Red
Thanks for all the feed back, much appreciated. I'll just order the green filter cleaner and be safe!
Old Mar 7, 2008 | 08:37 AM
GMRULZ's Avatar
GMRULZ
Cosidering both filters are a cotton gauze material (different color of course) I highly doubt that the K&N kit would damage the green filter.
Of course the Green filter company would tell you to use their kit...Lol...Thats a no brainer...
I used the K&N filter cleaner charger on mine over 6 months ago, just had it off a few days ago when I clocked my MAF 90 degree`s and put insulation on the upper rad hose to keep the heat soak off the IAT which is in the MAF, and found the filter to be nice and clean. No damage noted and I ran 11`s in the 1/4 in my bolt on car w/ green filter cleaned and oiled w/ a k&N kit. So no air restriction from say a breakdown in the material from using K&N products.
Of course Callaway would sell both kits, the companies won`t warranty their filters w/ out you using their oil.
However, the correct way to retain your warranty is to stay w/ the green filter company cleaner/charger kit. I just happened to already have the K&N kit and called CoH`s Tech line to verify if it was ok. He told me the same thing I already surmized, both are a cotton gauze filter.
Each to their own. I`m not trying to beat you up, I personaly think both will work, but the green filter kit is a better choice to retain your warranty if thats what you are concerned about. I was not concerned about the warranty.
Old Mar 7, 2008 | 01:11 PM
siffert's Avatar
siffert
Cosidering both filters are a cotton gauze material (different color of course) I highly doubt that the K&N kit would damage the green filter. Each to their own. I`m not trying to beat you up, I personaly think both will work, but the green filter kit is a better choice to retain your warranty if thats what you are concerned about. I was not concerned about the warranty.
The question is, do both have the exact same cotton material/contents/% and do both use the same oil material/content/%? Not concerned about warranty either, but since I highly doubt anyone knows the answers to both questions except the engineers at Green Filter and K&N. I do know you should not use clear oil on a green filter, nor green oil on a white filter. So I know there are differences between those two oils, aside from obvious color. I think it might be wise to stick with each one's recommended cleaner and oil, though in a pinch its good to know your experience.
Old Mar 7, 2008 | 02:04 PM
GMRULZ's Avatar
GMRULZ
The question is, do both have the exact same cotton material/contents/% and do both use the same oil material/content/%? Not concerned about warranty either, but since I highly doubt anyone knows the answers to both questions except the engineers at Green Filter and K&N. I do know you should not use clear oil on a green filter, nor green oil on a white filter. So I know there are differences between those two oils, aside from obvious color. I think it might be wise to stick with each one's recommended cleaner and oil, thought in a pinch its good to know your experience.
Fair enough.
Old Mar 7, 2008 | 04:46 PM
siffert's Avatar
siffert
Fair enough.
Very nice 1/4 mile time and 60'! Maybe I should start using K&N cleaner/oil in my Xcelerator (Honker clone) with Green Filter Co. white filter! I'll do anything to improve my time! What brand DR's do you use and at what pressure?
Old Mar 8, 2008 | 08:45 AM
GMRULZ's Avatar
GMRULZ
I borrowed a set of MT drag radials on 17 inch Firebird rims...Lol... Ran at 24psi. I ran 12.2 a previous time on the stock runflats at 28psi, I think the 60 was 1.87 if I remember correctly on the runflats. But that track was prepped much better than the one I used the drag radials on.
Old Mar 8, 2008 | 09:25 AM
siffert's Avatar
siffert
So do you attribute the .22 saved to the MT's DR's on your 11.98 run?
You figure .10 saved on your 60' giving you .2 on the ET?
Old Mar 8, 2008 | 02:55 PM
GMRULZ's Avatar
GMRULZ
Partially yes, the other would be better air on the 11.98 pass the DA was about 500 points lower to my recolection.
One thing I`ve noticed on years of racing my 96 Trans Am , that was a 4k stalled auto car, that if I hooked a better 60 foot by .10 it equaled .15 on the big end of the 1/4. That was with the TA and I had probably 350 passes in that car. I averaged them up. .15 1/4 reduction for .10 60 foot reduction was the norm.
I don`t have enough passes and seat time in this MN6 vette yet to really get a feel for how a MN6 .10 reduction works out to on the big end. I`m going to a rental in april and should have a better idea. It may be the same or it may be more of an increase. We`ll see.
I have a 2010 Camaro deposit down w/ Rick at Les Stanford that I will be getting in an auto for drag racing. I bought my vette mainly for street, to have fun in, hence the stick vs auto. Auto`s are much better for drag racing, Imho..Hope to have the best of both worlds by having both cars. My vette will stay stock internal but will get a blower for fun on the street, and my LS3 Camaro will get a big cam, big stall and the supporting bolt-ons for the track. I just hope they figure out how to remove TM from the pcm on the launch for the A6.
Old Mar 9, 2008 | 02:09 PM
siffert's Avatar
siffert
I think a few guys (incl Glennhl) here equate 2x on the C6 for each .10 60' reduction. My C6 A6 is mostly for the strip and thinking of getting the Dodge Challenger SRT in a few years...I like the looks better though no doubt will be slower than the Camero. I had a '97 Trans Am too, too bad they were not bringing back the Firebird instead of the Camero
Oh, am all for the removal of TM on the A6 launch...hope HP Tuner comes up with the solution
in their next version.
Old Mar 10, 2008 | 07:05 AM
GMRULZ's Avatar
GMRULZ
Having a car w/ a big stall like that, it 1/8th miled like a car w/ a lot more hp than it had but showed it had only 400rwhp on the big end by its mph. Thats probably why it equated to .15 on the big end in that car. The other`s you spoke of on here probably don`t have that kind of set up. The slips I have on the vette, I just averaged, and it came out to .18, but there are so few I hate to rely on them yet. Not to mention the variable of me shifting..Lol..
I`m w/ ya on the looks of the Challenger, pure retro, and thats what I like as well,(I`m 38) its just so darn heavy and LS engines are just so darn easy to modify for big gains. Not to mention the hookup we have here w/ the forum dealers vs paying 10k over sticker first year on the Challenger. Once its out a couple of years the price will come back down though..
I`ve always had a firebird of some sort since I was 16, I`m birdless currently and not happy my new pony car will be a chevy vice a pontiac. Manufacturing costs..,CAFE...Such is the world we live in today...
Old Mar 10, 2008 | 12:05 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I have one of the eariler Green Filters. I would not recommend that you mix & match on the cleaning. It may just be OK But for $20 why chance it?
To Cleaning a Callaway air filter
