I clean using a 1 part simple green:4 parts water solution....
Let dry 48 hours and then use an oil...
Which oil? you choose.
a) aersol K&N easy to apply , esy to see
b) wd40 easy to apply but invisible
c tranmission oil ( any varinat), visible but harder to apply
ok so I treat it like a K/N then, makes sense. The filter is one of the green filters, no harm with the k/n oil then?
The rep from Green Filter said that you should not use the K&N kit and oil on the Green Filter - something about the K&N oil not being correct for the fiber!
Steve
Steve
