Problem with driver window.
Old Mar 9, 2008 | 04:03 PM
purplehaze66's Avatar
purplehaze66
3rd Gear
Default Problem with driver window.
Hi,
I just bought a new 08' Vette in mid Dec. and about 4 days ago I started having problems with my driver side window. You know how when you open the door the window goes down a little then back up after you get in and close it. Well mine goes up and back down(not all the way), up and down, up and down. It will not stop until I hit the door lock. Same thing when I get out, will not stop until I lock it with the FOB.
Has this happened to anybody else? Or has anyone ever heard of this issue?
Thanks,
Joe
Old Mar 9, 2008 | 05:23 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
The constant up and down is a new one to me.
Try doing the standard window index
Get in start car push window button till it gets to top hold & for 4 seconds, repeat the hold for 4 seconds
Possibly that will work. If not dealer time!.
Old Mar 9, 2008 | 05:29 PM
racerx8's Avatar
racerx8
maybe it thinks it's an elevator sorry couldn't resist
seriously, try re-indexing the window as in previous post.
good luck !
Old Mar 9, 2008 | 05:36 PM
purplehaze66
3rd Gear
Default Tried it
Thanks,
I tried window indexing but it does not seem to do anything. When I hold up the button for 3-5 seconds and then let go I can hear this clicking noise in the door. I think its a relay making the noise.
This just makes me mad, I just got the car Dec 18 and I am already having a problem. You would think when you shell out this much money that you would not get theese kind of problems.
Guess I got to take it to the dealer. But I was hoping it would be something easy that I could do and not have to hassle with the dealer.
Thanks again,
Joe
Old Mar 9, 2008 | 05:39 PM
racerx8's Avatar
racerx8
Joe,
Have you tried disconnecting the neg battery cable, then reconnecting.
These electrical gremlins can be a pain in the ***.
Joe
Old Mar 9, 2008 | 05:53 PM
gotvet's Avatar
gotvet
Did this happen right after you washed it? I had the same problem after I gave mine a bath. My driver side door also quit working. Blew out the door handle with compressed air and re-indexed the window. Works fine now.
Old Mar 9, 2008 | 06:14 PM
oneblackvette's Avatar
oneblackvette
I agree with above.....
Remove neg battery for a few mins then reinstall and reindex again.
Old Mar 9, 2008 | 07:01 PM
purplehaze66
3rd Gear
Default I'll try that.
I give that a try and see what happens. Hopefully this is not going to happen everytime I wash my car.
Joe
Old Mar 9, 2008 | 09:00 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Old Apr 4, 2008 | 07:41 PM
Frogday's Avatar
Frogday
Did this get resolved by disconnecting the battery and then re-indexing the window? My passenger window just started doing this yesterday. Moves up and down about 1/2 inch until I reach over and press the lock button.
To Problem with driver window.
