Perfect Tire PSI ?
Old Mar 11, 2008 | 08:38 PM
waventure1's Avatar
waventure1
Default Perfect Tire PSI ?
Ok lets here it?
Z51 Runflats
Old Mar 11, 2008 | 08:44 PM
Miaugi's Avatar
Miaugi
30 - 32 would be about right but really there is no perfect number! It depends on the car, the road conditions, mileage on the tire, alignment, outside temperature, cruising speed, etc.
Old Mar 11, 2008 | 08:46 PM
waventure1's Avatar
waventure1
Ok I had them at 31 but car seemed to wonder on some roads. The tire shop has them at 35 now?
Old Mar 11, 2008 | 09:52 PM
Modshack's Avatar
Modshack
Put them back to 30 and get an alignment....
Wandering as you describe it is either tramlining (a function of wide tires and uneven road surfaces) or a por toe setting. One can't be fixed, the other can..
Old Mar 11, 2008 | 10:28 PM
VET4LES's Avatar
VET4LES
I ran 30 psi for the first 12,000 miles and noticed the rears were waring faster in the center. I lowered the pressure to 27 and at 18,000 miles they are about equal across the tire. I'm looking for 30,000 miles out of the Z51 tires.
Old Mar 12, 2008 | 06:26 AM
waventure1's Avatar
waventure1
That is alot of miles out of Z51 tires from what i have heard Thanks
Old Mar 12, 2008 | 06:53 AM
VET4LES's Avatar
VET4LES
I'm sure it will happen and maybe more. The trick is alignment, and air pressure. Of course no burn outs helps.
Old Mar 12, 2008 | 07:48 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I think the HOT pressure is what is really important since that is where we run most of the time. I think 32-34psi for even wear. For me this is 28 cold.
To Perfect Tire PSI ?
