Z06 Manifolds Vs LG pro Long tubes Similar mods
The only real comparisons that should be made are from stock to Z exhaust to LTs. Not from one car to another or from an LS7 to an LS2. That makes no sense. Regardless of the fact that LTs will produce more power than the Z manifolds and also set up a base for future mods. An actual power increase was achieved going from stock exhaust to Z exhaust(assuming the above numbers are acurate) That is it. Do not read into it any more than that. No LS7 to LS2 or this C6 to that C6. One car, one mod, and the results. Done. Thread over.
But something the corvette forum has always done for me and many others is to learn other options/alternatives to each and every part/vendor, learn tips/tricks to launching, bleeding clutches, etc. That is what makes this forum great.!!
We could all believe that every part will provide every HP and TQ that they claim, and every claim that this vendor or that vendor has the best, when only real world testing shows that.
Just like the Tornado test...obviously wasnt worth the foil it was made out of
Sure it would be wonderful to test every corvette on the same dyno, same day, same car, different parts. How realistic is that??? Who wants to drive cross country to test thier theories? If I had the cash to outlay for that, I wouldnt be trying to get results out of used parts.!
I am not bashing any particular vendor or anyone else, but I personally believe that the prices charged for Corvette headers/ xpipes/exhausts are way too much . That is my belief.
Thanks to Corvette Forum, i have been able to make some very educated decisions, and I hope I can provide that for some other people.!
And two different engines! I rest my case!
Ok guys, I just finished the mod (complete Z06 exhaust manifolds to mufflers) and ran 1/8 & 1/4 mile.
My car is a 2005 A4 with 3.15 gears & a honker it ran a best of 12.43 @ 112.x or 113.x & 90.xx in the eight. (too lazy to actually look it up) Taking the car off the jackstands and racing it in the Corvettes vs GTOs I ran the 1/8 mile and my MPH went up to 91.86 & 91.94 when we were not playing brake light racing.
On Wednesday, I went to a track rental it ran 12.40 @ 114.00. I had my own lane, no water so I heated the tires via a dry hop and the DA sucked. So it may be close but not exactly apples to apples.
My observations:
1.) The car dropped dead up top (flaps open Blaaaaaaaaaa)
2.) Traction was limited at best (I needed to change my launch technique, it could also be the dry hop vs water)
3.) The car really needs to be tuned if you want to maxmize this mod.
My opinion:
You can not compare the Z06 exhaust mod to Long tube headers. Daren I am truly sorry........ way too late to explain the benefits of the 32 inch primary tube which measures 1 & 3/4 inch vs 3 inch wide stock exhaust attached to exhaust manifolds) I cheaped out, I do not want any hassles with the inspection police
There is horespower to be gained with the Z06 setup. If you consider that motors are air pumps, improve the outflow and you also need to improve the inflow and of course a tune is necessary and not optional.
My intention is to add a intake (fast or weiand) then tune it and go back to the track. We'll see
BTW It is a bear when you install it on an auto as the autos were not made to accept the 3 inch pipes
Hope this little note helps ..... yea right some more gasoline on a already raging fire
My observations:
My opinion:
Tommy, you are a class act guy. I can appreciate everyone's opinion when it is approached in the manner that you speak! (even if I disagree to some level)..
We all have opinions, and they all stink!
So am i understanding that you did NOT have it tuned? If not, you gotta get that bad boy done...Changes that large cant be optimized properly with the stock tune!
Also, with more power comes traction problems! Thats Why i dont even bother with the runflats anymore, only race on Drag Radials.
Daren
Daren
My observations:
My opinion:
My observations:
My opinion:
I believe the Z06 manifolds have to be better than the stock manifolds. Are they as good as long tubes? I, along with most everyone else, really doubt it. Tommy's evidence is Z06 manifolds are worth maybe 1 mph in trap speeds (without a tune). My LG LT's were worth 4.5 mph in trap speed (corrected numbers, it was 5 mph uncorrected). And this also was without a tune.
The only way people will believe any comparison is if it's on the same car and the same dyno within a couple weeks or less apart.
Daren
Daren
Thank you!
I get invited to the track rental as entertainment Everyone knows the way I drive so I am the "test pilot", "warm up guy" and provide something for everybody to talk about.
Drag radials would be no fun as I would actually make a pass and possibly go straight
And yes the car really, really needs to be tuned, I have been very bad as I have not even run a scan to see how screwed up it is..... and it is
These engines are all about the package you put together, and the improvement from any one item aren't all that important. I'n my case, I'd like to get my car to around 425 rwhp while keeping stock driving manners, stock idle, and 100k mile reliability. At the same time, I'd like to pass our state inspection without any funny business, something that my current combo will never do. So, how do I meet my goals while spending the least amount of cash? The $200 Z06 manifold/cat/midpipe system seems like a no-brainer.
Totally agree.
I do believe that an LS3 can reach 425 RWHP with near stock manners but it will have require a well thought out as well as conservative package of parts...CAI, stealth cam with intake duration less than 220 and LSA >116, ZO6 exhaust manifold/ headpipe with converter, and maybe porting the exhaust port only in the heads
#33
I'd be very happy if I get into the 420-425 area with a combo like that. If it happens, my headers will be for sale the next day.
I paid $200 for the Z06 parts on eBay, and $1700 for LG headers, so the difference is pretty huge. The headers cost 8.5x as much!
#34
I'm lucky, our state only plugs into the computer to check for codes. If I had a tough inspection I would seriously consider the Z06 manifolds. I agree with your assessment, I wanted a car that was totally streetable. After the "mild" 224 cam I put in my LS1 Camaro, I decided to stay with the stock cam and heads on this car. It's an A6 auto and it only puts down 365 rwhp, but it runs 12.003 at 118.7 in Phoenix (that's not too shabby!). That's fast enough for me.
#35
Not on a properly tuned car they don't. Going from stock tune and manifolds to a custom tune and headers yes, but tune the car first, then put on headers and you will gain very little. The tune, leaning out the A/F, and adding tuning gives the majority of the gains, not the headers. We dyno'd two Z's, both with tunes, CAI's, and 160 stats, then added LG headers to one car and optimized the tune. It gained 14 ft lbs of midrange torque and 2 (that's two) peak RWHP. We did the same to my Z but with American Racing headers Vs. the LG's and it gained 12 ft lbs of midrange torque and 4 (four) peak RWHP. The factory Z06 manifolds are VERY good.
#36
Here's mine.
LG did the install:
Base: 05, A4, 3.15's, blackwing and RT 66 catback
347 HP / 346 Torque
After install of Z06 manifolds, converters and a modified H-pipe
367 hp / 362 tq
Done within 4 hours of each test without a tune.
LG did the install:
347 HP / 346 Torque
367 hp / 362 tq
#37
Where did you get your z06 manifolds from?
I got sent a z06 offroad x pipe by accident, thinking it was for the c6. I wonder if I could get z06 manifolds and hook up my 3" z06 magnaflow x pipe to my c6 2.5" magnaflow catback. hmmmm
#38
A 3" Z06 X-pipe won't bolt to a regular C6 exhaust unless you make an adapter (not hard for an exhaust shop).
#39
These are excellent numbers. I believe them. However, it's closer what I would expect out of the Z06 manifolds, 20 peak horsepower and 16 for torque. My LG Longtubes increased my car by 26 peak horsepower, but the real difference (which you would expect from long tubes) was 39 foot pounds of torque in the mid range.
