manual trans fluid
Old Mar 18, 2008 | 05:21 PM
REVAK's Avatar
REVAK
Default manual trans fluid
Those of you who saw an improvement using RP syncromax, has any one found anything that performed even better ? thanks in advance.....
Old Mar 18, 2008 | 06:58 PM
i_york's Avatar
i_york
Haven't used RP myself, but I think it's gonna be hard for anyone to answer this question unless you outline your specific requirements. For example, some trans oils are great when the ambient temperature is at a certain level, but don't work below a certain temperature threshold. Personally, I suspect the OE (GM) oil is probably the best compromise 'one size fits all' oil.
Cheers,
Ian.
Old Mar 18, 2008 | 08:18 PM
tmak26b's Avatar
tmak26b
The Syncromax is crap, the ATD from Amsoil is better, but not perfect as it is still notchy in the cold. I will try Redline next time around
To manual trans fluid
