Installed Z06 Mufflers
Old Mar 19, 2008 | 05:19 PM
Maui's Avatar
Maui
St. Jude Donor '08
Default Installed Z06 Mufflers
I picked up a set of barely used mufflers on the forum and a mild-to-wild from nakidparts. I had the mufflers installed today at a local muffler shop. The install went pretty easy. We kept the 3" pipes on the mufflers and fabricated a 2.5 x 3 reducer to connect them to my ARH x-pipe. The install took a little over an hour and he charged me a whopping $70. I had installed the mild-to-wild myself which took a total of about 15 min. Sorry I have no way to record the sound but it is awesome with the other mods I've done to this car.
Old Mar 19, 2008 | 05:28 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Old Mar 19, 2008 | 07:29 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Video clip would be nice, all the same
Old Mar 19, 2008 | 07:48 PM
Miaugi's Avatar
Miaugi
Old Mar 19, 2008 | 07:53 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Old Mar 19, 2008 | 08:34 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Old Mar 19, 2008 | 09:25 PM
07MontRedcp's Avatar
07MontRedcp
This is not intended as a "got ya" question but rather a clarification on a point i have been wondering about. I thought I had read, in the past, that the Z06 exhaust system was 3" but necked down to 2.5" at the mufflers. If I read your post correctly, you're saying that the Z06 muffler is 3" all the way through and that you had to reduce the input from 3" to 2.5" to adapt to your 2.5" over the axle exhaust pipe.
Could you expand??
BJK
Old Mar 19, 2008 | 09:59 PM
Maui's Avatar
Maui
St. Jude Donor '08
Could you expand??
BJK
The stock pipes reduce just before entering the muffler. I did not want to hack the muffler pipes so we kept the stock pipes and fabricated a reducer to go between the muffler pipe end and the x-pipe.
Old Mar 19, 2008 | 10:48 PM
From C6ZO62C8's Avatar
From C6ZO62C8
cool
Old Mar 20, 2008 | 12:17 AM
Kent1999's Avatar
Kent1999
The Z06 exhaust system is 3 inches everywhere EXCEPT for about 1 inch (yes, 1 inch!) before it enters the muffler, where it necks down to 2.5 inches.
Why? The world may never know...
Old Mar 20, 2008 | 08:32 AM
c6 Houston's Avatar
c6 Houston
Is it also 2.5" inside the Z06 mufflers ?
Old Mar 20, 2008 | 03:41 PM
Maui's Avatar
Maui
St. Jude Donor '08
I can feel a little extra power over the GM performance exhaust I had previously.
GM claims the NPP exhaust provides 6 more horsepower. I am assuming that is when the valve is open. Any info on that would be appreciated.
To Installed Z06 Mufflers
