Ceramic Brake Pads
Old Mar 21, 2008 | 06:35 AM
tloon's Avatar
tloon
Default Ceramic Brake Pads
The local A/C Delco dealer has a set of ceramic brake pads that he says will fit the standard set up, but not the Z51 according to the numbers. I have seen conflicting info on weather that is true. Are all the pads in fact the same on the base and Z51, as far as being interchangable? Will his "base" set up fit the Z51?
Old Mar 21, 2008 | 07:04 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Yes. The pads are the same size Z51 or standard, C6 or C5. I've been running ceramics for street duty for years.
Old Mar 21, 2008 | 07:39 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Originally Posted by Joe_G
Yes. The pads are the same Z51 or standard, C6 or C5. I've been running ceramics for street duty for years.
Old Mar 21, 2008 | 08:26 AM
Buffy's Avatar
Buffy
The pads are the same size; they're not the same composition. But if you want ceramic pads, then these should work fine. The OEM Z51 pads are more agressive (and, of course, a lot dustier and more prone to squeal).
To Ceramic Brake Pads
