Tunnel plate installaton help please
Old Mar 22, 2008 | 05:45 PM
Larry R's Avatar
Larry R
Default Tunnel plate installaton help please
I am getting ready to install the LAPD tunnel plate. The exhaust needs to come off, and I can see where to disconnect it towards the front, but am not sure where to disconnect it at the rear. There are clamps but it is not clear to me if there is a joint there. Can the front be unhooked and then the system let down enough to install the new plate? Any suggestions or comments will be appreciated. Thanks, Larry BTW, this is on an '08 coupe. NPP exhaust
Old Mar 22, 2008 | 05:48 PM
timd38's Avatar
timd38
Disconnect at the "X" or "H" pipe depending on what exhaust you have. You have to remove it to get the old plate off and the new plate on. Elite has great instructions on their website.
Old Mar 22, 2008 | 06:26 PM
Larry R's Avatar
Larry R
Sorry, but I am not finding Elite. Is there more to the name? Thanks
Old Mar 22, 2008 | 07:07 PM
johnodrake's Avatar
johnodrake
Moderator
Here is their site: http://www.eliteengineeringusa.com/
Old Mar 22, 2008 | 07:08 PM
bigdogk9's Avatar
bigdogk9
I just replaced mine this past week and it only took about an hour. I disconnected the H-pipe at the front and disconnected the spring holder toward the rear of the H-pipe to allow it to be pulled back and down. I was able to slide the old plate out toward the front and the new plate in. It was really easy once I figured it out.
Good Luck!
Old Mar 22, 2008 | 07:19 PM
Bandit1's Avatar
Bandit1
Larry--Its "Elite Engineering USA" ........try this page for your install.
http://eliteengineeringusa.com/Insta...hermal-Abs.pdf
In answer to your question.........yes you will have to remove the oem H-pipe. Be careful when loosening the bolts on the H-pipe to cat pipes flange. Take your time and preferably do them by hand. Very easily sheared. You will have to remove the spring holder nuts and also loosen the clamps at the H-pipe to the over the axle pipes. Drop the front, wiggle the rear free and then drop the H-pipe down. Ready to install your tunnel plate. I did mine the same time I swapped out the exhaust. And...........do not over torque the tunnel plate bolts. Hope this helped. John
Old Mar 22, 2008 | 07:23 PM
Bandit1's Avatar
Bandit1
Isn't this Forum great?!! Looking at this thread alone............in a matter of minutes, you have support from members in WI, VA, TX, and GA all trying to help you out. Outstanding!!! Too bad the Gov doesn't work that efficiently.
Old Mar 22, 2008 | 07:31 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Consider installing the new plate on top of the old one. Why not double up? I did.
Old Mar 22, 2008 | 07:48 PM
VET4LES's Avatar
VET4LES
Great idea.
Old Mar 23, 2008 | 01:12 AM
Larry R's Avatar
Larry R
That is a great idea. Would longer bolts might be needed?
Old Mar 23, 2008 | 01:13 AM
Larry R's Avatar
Larry R
Old Mar 23, 2008 | 03:32 AM
HuskerBullet's Avatar
HuskerBullet
Yea, great idea! I plan on installing my LAPD 1/4" plate next weekend. It looks like the original plate is about 1/8" thick, so adding the two together would increase the stiffness that their 3/8" plate would have....it shall be done!
Old Mar 23, 2008 | 07:40 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Two things:
1. You DON"T need to remove the H-pipe. Disconnect the front at the flanges and the mid hanger.
2. You can use a 1/4 plate with the OEM- the OEM bolts will work.
BTW, I had to retorque the bolts (89 in-lbs) twice after some driving before they settled down and stayed tight.
Old Mar 23, 2008 | 10:03 AM
Larry R's Avatar
Larry R
Originally Posted by dave pawlowski
Two things:
Good tips, thanks.
Old Mar 23, 2008 | 05:39 PM
jrpedraza's Avatar
jrpedraza
I haven't installed mine yet, I'll be ordering the 3/8 plate from LAPD this week along with headers and X-pipe; my question is can the bolts be retorqued without removing the entire system?
I think I'll only use the 3/8 LAPD plate, instead of doubling up with the oem plate; I just don't think another 1/8 inch will help much.
Anyone have any 'real-world' temperature reduction numbers on these tunnel plates? Or even what it 'seems' like would be good enough.
Thanks,
JR
Old Mar 24, 2008 | 12:54 AM
Drumhawk's Avatar
Drumhawk
This thread was very helpful as I'm gonna install my Elite tunnel plate next month, thanks guys.
Old Mar 24, 2008 | 07:49 AM
davekp78's Avatar
davekp78
Thanks,
JR
I don't think the OEM bolts are long enough for any thickness over 3/8" total. You can retorque them without removing anything- just crawl under. I tried to measure the temps before and after but the results were inconclusive- I don't drive for hours on end, and I found the console area to be more affected by interior temp after being parked in the sun.
Old Mar 24, 2008 | 11:53 AM
Larry R's Avatar
Larry R
Would using Locktite help keep the bolts tight?
Old Mar 24, 2008 | 10:56 PM
jrpedraza's Avatar
jrpedraza
Thanks for the info, it looks like I'll have to get some new bolts to mount the new tunnel plate. As far as the temps go, I had noticed that things in my center console were very hot after a 'not so long' trip from the office.
I'll report back when I install it.
JR
To Tunnel plate installaton help please
