What gear?
Old Mar 24, 2008 | 08:27 AM
ALK's Avatar
ALK
Default What gear?
Riding along in my 07 A6 C6 at 50-55 mph and I punch it, it goes into passing gear. What gear does it shift down to?
Old Mar 25, 2008 | 07:33 AM
ALK's Avatar
ALK
Anybody, please respond.
Old Mar 25, 2008 | 07:44 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
No simple answer. What gear were you in? How hard did you step on it? You could duplicate the condition and then just count the upshifts til 6th.
Old Mar 25, 2008 | 12:36 PM
sodapop's Avatar
sodapop
Third for sure at 50-55
Old Mar 25, 2008 | 09:47 PM
Vette_DD's Avatar
Vette_DD
Do it again tomorrow and watch your tach. If your rpm jumped immediately to about 3000 rpm, it dropped to 3rd. 4500 = 2nd, 2250 = 4th.
Old Mar 25, 2008 | 11:30 PM
TMyers's Avatar
TMyers
It like my 06 it jumped to 2nd. Make sure you are pointing where you want to go.
Old Mar 25, 2008 | 11:45 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
At a steady 50-55 mph, then floored in an A6 with a stock 2.56 rear it will hit second gear every time.
Old Mar 25, 2008 | 11:46 PM
Silverspeed
See above.
Old Mar 26, 2008 | 03:41 PM
User 2623's Avatar
User 2623
If your in sport mode and paddle shift your way to sixth gear you'll top out at 75-80. If you down shift twice you you get into 3rd or fourth = passing mode as you decribe it.
So in auto driving mode [@ 50-55] depending up which gear your are in you'll most likely drop into 3rd or 4th. As far as I can tell.
Old Mar 26, 2008 | 03:47 PM
Silverspeed
Incorrect. At a steady cruise at 50-55 mph and "punching it" in an A6 with 2.56 gears it will drop to second gear.
Old Mar 26, 2008 | 04:18 PM
DaveC6's Avatar
DaveC6
I agree with 2nd gear. The shift tables say the WOT 3->2 shift will be at 71mph or less. One way to test is to do it in S mode. As soon as it shifts use the paddles to upshift one gear, then it should say 3 on the HUD/DIC.
Old Mar 26, 2008 | 04:22 PM
jmudreamvette's Avatar
jmudreamvette
2nd gear for sure till about 80 then 3rd hits, thats what mine did...
Old Mar 26, 2008 | 06:41 PM
mcwire's Avatar
mcwire
Sure feels good, but, must be, quite, a strain, on the drive train. -- --
Old Mar 26, 2008 | 07:46 PM
Purdue's Avatar
Purdue
A 50-55mph punch will drop down from 6th to 2nd gear
Old Mar 26, 2008 | 10:42 PM
gitgone's Avatar
gitgone
If by "punch it" you mean "floor it" or WOT, my '08 Z51 will:
1) shift to 1st when traveling less than ~30mph
and
2) shift to 2nd when traveling between ~30mph and ~65mph
Both are fun, but as was stated before, be sure you are pointed where you want to go with some room to run!
To What gear?
