Fuse # 10 only controls the skip shift lockout. The people that thought they pulled fuse #10 actually pulled another fuse (position # 10) thinking that it was fuse # 10 and this did control the rear tail light. I did it mistakenly also the first time. You must really study the fuse layout print. Use this diagram to make sure.
Charlie [/IMG]
They pulled the wrong fuse. I added the proper resistor to the 10 fuse slot months ago and get a shift light but no limitation on actual shifting and no codes. I meant to correct the same comments. Chucky7 thanks for doing it here.
