Help w/Predator
Old Mar 26, 2008 | 07:45 PM
stanstiles's Avatar
stanstiles
Default Help w/Predator
I'd like to pick up a used Predator. Got a '05 VR Roadster. Trouble is I've read so many things about the predator, I guess I've gotten myself screwed up.
Basically, if I buy a used unit, can I use it on my car without sending it to the factory? Or, is there something else I'd need to do before I use it?
Thanks to all who answer in advance.
Old Mar 26, 2008 | 08:08 PM
BEZ06's Avatar
BEZ06
If the original owner puts the stock tune back into his car, then the Predator will be able to be used on another car without anything else being done to it - no sending it to the factory or anything else.
So....you just have to make sure that the original owner definitely has put his car back to the stock tune before you buy it.
BTW, you need the U7191 for the 2005 LS2.
Bob
Old Mar 26, 2008 | 08:16 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Bob
I have a u7194 that I returned to stock. Ill be getting a HP pro soon
and be selling the predator.I learned a lot using the predator on my 07 ls2. I dont know if it will work on an 05
Old Mar 26, 2008 | 10:14 PM
BEZ06's Avatar
BEZ06
You say you have a 2005, so this post would apply to you :
http://forums.corvetteforum.com/show...11&postcount=4
And you definitely require the U7191 for a 2005
Bob
To Help w/Predator
