Possible to add a telescoping column?
Old Mar 27, 2008 | 07:53 AM
EmilT's Avatar
EmilT
Default Possible to add a telescoping column?
I have an '08 2LT as I have had HUD on a C5 and never used. I do find I would like to have the steering wheel a little closer. Is it possible mechanically to add the telescoping funcion? Any aftermarket hub extenders available? Any suggestions would be welcome.
Old Mar 28, 2008 | 10:38 AM
cerino2000's Avatar
cerino2000
Probably cost you less headache and wallet ache to trade your car in for a 3LT car. They do in fact use two different harnesses between the two option packages.
Old Mar 28, 2008 | 12:49 PM
Gramps's Avatar
Gramps
I had an Acura NSX and one of the frequent mods was aftermarket steering wheel, and hub fitments. Anything like that available for Corvettes. I am willing (foolishly?) to forego the hair bag.
Old Mar 28, 2008 | 04:38 PM
J.Yo's Avatar
J.Yo
EmilT, I had the same question a year ago when I got my 07. I spent a bit of time jammed in the driver's footwell trying to figure out what I can do to get the steering wheel closer to me. I looked through the tech manual to see the differences between the telescoping and non-telescoping steering columns, and was not able to make a clear determination.
I'm going to see if I can get my hand on a used telescoping steering column and see how I can retro fit it. I wouldn't need the electrical connection, as I would make it so I can manually adjust the screw mechanism that telescopes the column, then just leave it.
Maybe we can just modify the non-telescoping column. The only reason I don't like the spacer idea, even with the stock airbag, is that it puts the turn signal stalk out of easy reach. I noticed this on a Miata that I added a hub extender and aftermarket steering wheel onto.
Anyone else have any useful knowledge of the telescoping or non-telescoping columns?
To Possible to add a telescoping column?
