160 deg. stat
Old Mar 27, 2008 | 01:26 PM
c6 Houston's Avatar
c6 Houston
Default 160 deg. stat
Where is the cheapest place to get a good 160 deg. stat. ?
Old Mar 27, 2008 | 01:43 PM
miroch's Avatar
miroch
Maryland Speed has a good price...
http://marylandspeed.com/slp-160-deg...228-p-474.html
Old Mar 27, 2008 | 02:02 PM
Buddy A's Avatar
Buddy A
I got one from 21st Century Musclecars for like $21 just FYI
Old Mar 27, 2008 | 03:28 PM
Silverton's Avatar
Silverton
Be careful, t-stats come either: (1) with a housing, or (2) without a housing. I recently installed a 160 deg. t-stat, and found out the hard way. I have a '07 Z51, that required a t-stat with a housing. Other '07's do not require a housing. Go figure!
Old Mar 27, 2008 | 03:51 PM
NIGHTSTALKER's Avatar
NIGHTSTALKER
I have an 07 Z51 and didn't need a housing I just re-used the factory gasket.
Old Mar 27, 2008 | 03:59 PM
glennhl's Avatar
glennhl
I have an 06 QX1 and it also did not need a housing. I also re-used the factory gasket.
Old Mar 27, 2008 | 04:24 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Old Mar 27, 2008 | 05:12 PM
Aaron's-coupe's Avatar
Aaron's-coupe
I think that this was one of the changes in the LS1 and LS2 water pumps. I thought that the LS2 changed the T-Stat to the old SBC style T-stat and did not require a housing.
Old Mar 27, 2008 | 07:09 PM
vettl83's Avatar
vettl83
GM sells the gasket and housing as a set, thats why if ya don't get the housing you have to use the old gasket. GM recomends that they be replaced as a set, don't ask me why. I've done it both ways without issues, just make sure the little square notch on the gasket is seated in the little square on the housing, don't ask me how I know that.
Old Mar 27, 2008 | 07:19 PM
C5pilot's Avatar
C5pilot
07 Z51 & my buddies 06 Z51, no housing needed.
Old Mar 28, 2008 | 08:42 AM
6Speeder's Avatar
6Speeder
No housing required. I got mine from Autozone, it's a special order, ask for one for a late LS1. Cost $17.00, took 3 days to get.
To 160 deg. stat
