Non- Run Flat Tire Question
Old Mar 29, 2008 | 04:45 PM
TMRoc's Avatar
TMRoc
Default Non- Run Flat Tire Question
What type of spare do you use, if your not running RFT?
Old Mar 29, 2008 | 05:46 PM
PCMusicGuy's Avatar
PCMusicGuy
I suspect most would forgo the spare and carry around plug kits and a small 12v compressor.
Old Mar 29, 2008 | 05:53 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Maybe you know something I don't, but where did you find the spare?
Old Mar 30, 2008 | 01:47 PM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
Don't run a spare. Get yourself a patch kit and a good cell phone.
Old Mar 30, 2008 | 01:59 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
GTO spares fit with minor grinding on the hub if you don't have Z51 brakes. They will not fit over Z51 brakes. I used to carry one in my C5 for a while in the center cubby but it was a hassle to stap it in and not wise to leave it loose in the cargo area (it might clobber you in an accident). Drag racers buy them to put on front bias ply tires for a poor man's drag pack.
Old Mar 30, 2008 | 03:39 PM
runutzzzzz's Avatar
runutzzzzz
Patch kit with a compressor, Roadside assistance card and cell phone
Old Mar 30, 2008 | 03:52 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
And depending on your religion possibly a St Christopher’s medal
They have faults no doubt, but I will use RFs
Old Mar 30, 2008 | 04:00 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Conti Comfort Kit, cell phone.
Old Mar 30, 2008 | 04:14 PM
C2RMartinez's Avatar
C2RMartinez
Definitely Go With The Patch Kit & Compressor, And Hopefully Onstar
Old Mar 30, 2008 | 04:33 PM
Wass's Avatar
Wass
St. Jude Donor '09-'11
Ditto!
Old Mar 30, 2008 | 04:51 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I carry a plug kit from walmart in all my vehicles. Cheap and comes in a nice little case with all tools except pliers to pull out screws. Has come in handy several times.
Old Mar 30, 2008 | 04:55 PM
vetteblack's Avatar
vetteblack
I dont have the run flats, but I still carry I tire repair kit. Cell phone is the best tool, it can get you out of any flat tire.
Old Mar 30, 2008 | 08:57 PM
dkrhardy's Avatar
dkrhardy
Conti kits is one option, but what about the Fix-A-Flat cans? There are some that are NOT water based so there is no corrosion issue. I used one on another car, worked great, and when the tire was removed from the rim the stuff just peeled off and the tire was repaired with an internal patch. Conti Kit or can may render the pressure sensor inop, but inop is inop!
Old Mar 30, 2008 | 10:06 PM
yell03's Avatar
yell03
My new 911 not only doesn't have runflats, but it also has no spare.
They give you a tire compressor and goop.
I bought myself a plug kit just in case, oh yea, I always carry a cell phone.
Howard
Old Mar 31, 2008 | 12:33 AM
corvette pilot's Avatar
0corvette pilot
Former Vendor
I just chance it. no kit. Haven't had an actual flat in 25 years. (knocks on wood!)
Old Mar 31, 2008 | 08:34 AM
Buffy's Avatar
Buffy
Old Mar 31, 2008 | 10:38 AM
haljensen's Avatar
haljensen
Which size spare are you going to carry? A 25.71" for the front or a 26.85 " for the rear? There is a 4.25% difference in diameter.
Oversized on the front will cause A/H problems and undersized on the rear will also cause A/H problems and T/C problems AND probably cause excessive wear on the limited slip. Might even cause ABS problems with the computer reading different wheel speeds L to R.
To Non- Run Flat Tire Question
Old Mar 31, 2008 | 12:32 PM
RogerTheDodger's Avatar
RogerTheDodger
St. Jude Donor '08
Both times I have had a flat, was out of range of the cel fone(Central California in the country) so always carry a patch kit and know how too use it, especially if you travel out of the city, dont depend ont the cel to work!!
Old Mar 31, 2008 | 12:34 PM
andreas g.'s Avatar
andreas g.
First of all, where would you carry a spare? Second, with the tires today they just don't go flat or blow out. So with a nail or what ever you would get a small leak if any leak at all. Usually you notice the nail and it leaks when you take it out. So don't take it out until you get to a place where it can be repaired.
Old Mar 31, 2008 | 02:04 PM
Fuego's Avatar
Fuego
I had a blow out last year inmy 2000 mustang GT with Falken tires. First one in like 15 years.
