*** Hotchkis Sway Bars ***
Old Apr 1, 2008 | 02:11 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Default *** Hotchkis Sway Bars ***
C6 Corvette Sport Sway Bars
Features:
-Lightweight, durable 1.25” (1 ¼”) tubular steel front sway bar. 20% Stiffer than Z51 & ZO6
-Lightweight, durable 1.125” (1 1/8”) adjustable tubular steel rear sway bar. Stiffness increase on Z51 +15%, +45%, +80%. Stiffness increase on ZO6 -15%, Same, +30%
-Factory style oil impregnated rubber bushings included
-Gloss black powder coat finish
$354.95 + Shipping
http://www.thelapd.com/index.php?mai...roducts_id=332
Thank you, Hanna
(818)998-3966
Old Apr 1, 2008 | 02:21 PM
TTRotary's Avatar
TTRotary
Nice price Hanna. On question though: the diameters you cite are the exaat same as the C6 Z51 bars, (32mm fr 25mm rr), so how is the substantial increase in stiffness achieved? Thanks.
Old Apr 1, 2008 | 02:56 PM
overrev64's Avatar
overrev64
Diameter alone does not dictate stiffness. The type of material the bar is made from plays a big part in it and also the length of the bar from the pivot point to the link. (shorter span produces a stiffer bar)
Old Apr 1, 2008 | 03:08 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Thank you overrev64
Old Apr 1, 2008 | 05:33 PM
TTRotary's Avatar
TTRotary
I know plenty about suspension geometry, thank you. Given that front bar geometry is identical, that leaves only wall thickness to affect stiffness. More or less, a nearly solid bar would be required to produce a 100% increase in stiffness, given same geometry. This seems unlikely, since they are "hollow" bars. So my questions remains: how was the 100% increase in stiffness achieved?
Thank you in advance. Also, are the bushings stiffer and what role do they play.
Old Apr 1, 2008 | 05:44 PM
TTRotary's Avatar
TTRotary
Originally Posted by L.A.P.D.
•Lightweight, durable 1.25” (1 ¼”) tubular steel front sway bar. 115% stiffer than Z51.
•Lightweight, durable 1” adjustable tubular steel rear sway bar.
Stiffness increase over Z51 +60%, +100%, +150%.
OK as I suspected, these stiffness increases are not correct. From the Hotchkis website:
for a good price nonetheless.
Old Apr 1, 2008 | 07:40 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
I fixed it.... Thank you for the heads up.... Sorry about the confusion.
-Hanna
Old Apr 1, 2008 | 08:46 PM
NIGHTSTALKER's Avatar
NIGHTSTALKER
I wish you could get them in red
Old Apr 2, 2008 | 08:01 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Heres a little more info from the Hotchkis website.
The hollow tube bars measure 1.25-inches in front and 1.125-inches in the rear, and are 20% stiffer than stock in front and are adjustable from +30% to -15% stiffer in the rear. The result is dramatically improved cornering potential, chassis balance and steering response. Besides offering exceptional handling improvements for street driving, Hotchkis sway bars work extremely well in autocross, road course, and open road racing applications. The lightweight hollow sway bars are formed on a CNC machine, powder coated gloss black for durability and come with special high durometer dry lube impregnated rubber bushings. Stock end links are retained to maintain a quiet ride on the street. Thanks to added adjustability, the new Hotchkis C6 sway bar package reduces body roll, increases vehicle control, and adds a new level of driver feedback and control to any late-model Corvette, even razor-sharp Z06 and Z51 models.
If you have any other questions feel free to let me know.
Thank you,Hanna
(818)998-3966
Old Apr 9, 2008 | 02:48 PM
miami08VETTE's Avatar
miami08VETTE
I had Hotchkis TVS package on my previous car, a 2004 350Z. I really liked the products. Has anyone used these on a Z51 as an upgrade that can comment on their results and what has been found to be the optimum setup for street performance( aka which hole/settings to use)? Lastly would these further benefit from upgraded bushings versus the rubber ones that come with them in the kit? My goal is to improve body roll and high speed turn in while at the same time not overly affecting daily drive comfort.
Old Apr 9, 2008 | 03:03 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
I'm curious about this one too. I have an 05 Z51 and am interested in bushings/sway bars.
Old Apr 9, 2008 | 04:27 PM
bowmanized's Avatar
bowmanized
I really like this setup for a couple reasons.
I come from the school where you use spring rate and coilovers to do their job not sway bars to add roll stiffness. Sway bars should be used to tune the overall understeer/oversteer characteristics rather than add tons of wheel rate. When you use a huge bar that adds so much wheel rate that you have to use very soft spring rates to have any compliance in the suspension whatsoever. Then the stofter springs cause a lot of dive and squat. Less than ideal. Quoting Gary "what's the point of having independent suspension if you're going to tie them together with a huge bar.
Furthermore, the stock endlinks are nice and quiet. They have rubber in them for a reason. The other ones are better yes but they cause noise which can be annoying for a street car.
Very nice and for less than 1/2 the price of most you really can't do better.
That said if you think you'll have a dialed suspension with just the bars you're sorely mistaken. However with a proper coilover setup or even an upgraded leaf/shock package they work very well.
Just my .02
Old Apr 9, 2008 | 05:13 PM
miami08VETTE
Just my .02
I understand and agree with your comments. On my 350Z I used both the Hotchkis bars and springs and they made a significant improvement. Since I already have Z51, I guess the main question is will upgrading to these bars make a significant/woth the money difference to roll resistance and HS turn in? I know it won't be the do-all/end-all of a coilover upgrade.
Old Apr 9, 2008 | 05:35 PM
bowmanized's Avatar
bowmanized
I think they're worth it. The factory setup understeers a lot and you can dial out some of that by running the rear bar in the middle.
Old Apr 9, 2008 | 06:54 PM
miami08VETTE
Old Apr 10, 2008 | 03:35 AM
AintQik's Avatar
AintQik
I've got them on my Z51 but didn't get a chance to drive it before I got deployed. I'll let ya know in a few months
I set the rear on the middle hole. That sound about right for a street car?
To *** Hotchkis Sway Bars ***
