Headers - Coated or Uncoated?
Old Apr 2, 2008 | 05:32 PM
BaBa Booey's Avatar
BaBa Booey
Default Headers - Coated or Uncoated?
I've been considering headers for my '07 and have been trying to gather all the info. I can.
I like the idea of keeping some of the heat out of the engine bay but have also read detonation could be an issue. So I'd like to get some opinions on ceramic coated vs. SS. headers.
Pro/Cons of each?
Anyone have coated headers? Any issues? Worth the $?
Or is engine bay heat not even an issue with SS headers so don't even bother with coated.
What say you?
Old Apr 2, 2008 | 06:40 PM
Miaugi's Avatar
Miaugi
I had my complete Kooks system coated ar SwainTech in NY, very happy with the way they look and the lack of radiant heat. I will do it again next time (if there is a next time) as well!
Old Apr 2, 2008 | 06:41 PM
XvettemanX's Avatar
XvettemanX
coated.
Old Apr 2, 2008 | 06:49 PM
vettl83's Avatar
vettl83
Coated, just for the cosmetic value alone was worth it to me. My 91 ZR1 doesn't have them coated and they discolored. Good thing you can barely see em on an LT5.
Old Apr 2, 2008 | 07:01 PM
SpinMonster's Avatar
SpinMonster
Hot Rod mag had an article showing the use of a temp gun pointed at the header on a running car that read 201degrees. I would have done it had I known it was that affective.
Old Apr 2, 2008 | 07:22 PM
TehZ's Avatar
TehZ
Pay the $300 and get them coated. Not so much for reduction of heat soak in the engine bay area but for header longevity alone.
Old Apr 2, 2008 | 07:30 PM
3 Z06ZR1's Avatar
3 Z06ZR1
love my coated headers
Old Apr 2, 2008 | 10:05 PM
1.8t's Avatar
1.8t
Coated. I can run my car all out. Come back and park it and no joke after 30ish minutes I can touch my headers for an extended periode of time without burning myself. The coating is much more effective than I ever imagined. I have the Jet Hot 1700 coating in Sterling
Old Apr 2, 2008 | 10:14 PM
GeistC6's Avatar
GeistC6
Coated for me...
Old Apr 2, 2008 | 10:37 PM
glennhl's Avatar
glennhl
Carbon Steel, it's good to coat them for the temp reduction and rust prevention.
300 series Stainless Steel: No need to coat them, they don't rust and they have 1/3 the thermal conductivity which keeps them cool even without the coating. But, if you want them to be pretty, definitely coat them, they look great that way.
Old Apr 3, 2008 | 01:04 AM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
They may have 1/3 the conductivity, but the coating is still going to keep them cooler, along with all the parts around them. Coat 'em!
Old Apr 3, 2008 | 02:04 AM
vlocty's Avatar
vlocty
I coated my LG's for 3 reasons:
1. Looks - I like that they don't change color after use.
2. Radiant heat - any little thing to keep the engine bay cooler.
3. read somewhere on the forum that it prevents you from getting O2 sensor errors. I believe that this is due to the exhaust gases being hotter so the cat works more effieciently. Makes some sense to me. 6k mi. and no issues.
Old Apr 3, 2008 | 02:14 AM
HuskerBullet's Avatar
HuskerBullet
I have my 91 Camaro headers Jet Hot coated with the Sterling, love it, and will do it to the headers I eventually will purchase for the Vette.
Keep in mind, Stainless Steel will rust unless it is coated. It is not impervious to the bonding of oxygen as steel contains the elements of iron, carbon and nickel; iron bonds with oxygen real easy, so you eventually will see really small rust dots. Get 'em coated.
Old Apr 3, 2008 | 03:13 AM
MARSC6's Avatar
MARSC6
Just the look is worth it. Lay a coated set next to uncoated. Big difference.
Old Apr 3, 2008 | 08:29 AM
Miaugi's Avatar
Miaugi
...I went with SwainTech as they have the best thermal coating IMHO, with my car running I can actually touch the header right at the heads without leaving skin on it!
And they're even cooler further down past the collectors to the point you can lay your entire hand on them without needing medical attention!
Old Apr 3, 2008 | 09:29 AM
Wallacefl's Avatar
Wallacefl
just a question ...did it lower the noise level in the cockpit?
Old Apr 3, 2008 | 09:39 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
coated...and how many beers did that take ...
no, not really, maybe.... they will, however, change the sound
To Headers - Coated or Uncoated?
Old Apr 3, 2008 | 09:54 AM
Miaugi's Avatar
Miaugi
I would say no it didn't, or if it did not by much. I still get the valve train noise which is typical of what happens with headers installed although it is low and I only can hear it with the hood up.
Originally Posted by Zig
coated...and how many beers did that take ... [/i]
As stupid as it sounds (to touch the header of a running car that is) not that many!
You start off slow, like by getting near it, then wetting your finger and doing a quick brush of the header (like checking a wood stove to see if it's hot) and then before you know it....you discover you can actually touch the header momentarily without any pain....or..."how to amaze your friends"!
Old Apr 3, 2008 | 10:22 AM
Finster07's Avatar
Finster07
I agree with 1 and 2. I love my cherry red coated Kooks. Got the check engine light with all the sensors hooked up the second day. But I knew I would need a tune. Coating is the only way to go. And they look great.
Old Apr 3, 2008 | 11:17 AM
Vito.A's Avatar
Vito.A
Default Emissions check: Do not coat
If you have an emissions check in your area, you may not want to coat stainless headers. The stainless coloring will distort just enough to look stock, but if you coat them it will set off all the alarms when the guys look under the car.
If you install mild steel headers, you really have no choice but to coat them as they will not hold up in severe weather.
