160 thermostat
Old Apr 5, 2008 | 10:57 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
Default 160 thermostat
Where is a good spot to get a 160 thermostat without spending 40$
thanks
07 C6
Old Apr 6, 2008 | 02:32 AM
dgreer26's Avatar
dgreer26
got mine on ebay...........about 25 bucks shipped to my door!
Old Apr 6, 2008 | 08:22 AM
6Speeder's Avatar
6Speeder
Local auto parts store, Autozone, Checker, Pep Boys, etc. Special order item, Mr Gasket 160 thermostat for a late LS1, $17.00.
Old Apr 6, 2008 | 08:24 AM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
I tried two cheaper 160 stats but my running temps would hang in the 140's and 150's. I finally tried a LPE stat and a good thermometer and tested them on the stove. The LPE was the only one that worked correctly that I tested.
Old Apr 6, 2008 | 11:52 AM
6Speeder's Avatar
6Speeder
The Mr Gasket thermostat has worked perfectly for me.
Old Apr 6, 2008 | 12:28 PM
11secondGP's Avatar
11secondGP
Spent $15 at autozone/kragen. It works perfectly.
Old Apr 6, 2008 | 03:52 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
I just ordered the mr gasket 160 and offroad pipe from jegs
thermostat was 12.99 thank you so much for your help
now if I could find an ATI Procharger complete kit with 6 psi Boost
thanks again guys
Old Apr 6, 2008 | 10:42 PM
Z06forski's Avatar
Z06forski
Default autozone
$11.58 at autozone and has worked well for several months.
not that you asked, but when you change it you can put a rag in a pastic baggie and shove that in to the engine block so you lose minimal fluid and no burping really needed.
Old Apr 6, 2008 | 10:58 PM
Memphomaniac's Avatar
Memphomaniac
Keep in mind I'm a newbie. Can someone tell me the advantages & disadvantages to running a cooler thermostat?
Cheers!
Old Apr 7, 2008 | 12:02 AM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
there are two types, the short one and the long/sprin loaded one, if youre in the north, get the spring loaded one......I had the cheap $15 one and once the temps dipped below 30, the car ran @150degrees and screwed up my tune, the car ran like crap!!!!.......those that live in the South wont know the diff
the $15 thermo
the $45 thermo
Old Apr 7, 2008 | 12:50 AM
Z06forski's Avatar
Z06forski
the $15 thermo
the $45 thermo
the one i bought looks exactly like the one pictured for $45........and both look just like the stock unit....
Old Apr 7, 2008 | 02:30 AM
11secondGP's Avatar
11secondGP
The one i got looked just like the stock unit as well. I wouldnt have put a different looking tstat in my car. Coolant temps are fine.
Old Apr 7, 2008 | 08:26 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
the $15 thermo
the $45 thermo
The $15 one is WRONG for the LS series engines.
Old Apr 7, 2008 | 08:27 AM
davekp78's Avatar
davekp78
Cheers!
Do a search.
More discussion than you care to hear.
Old Apr 7, 2008 | 11:10 AM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
I know, the one that sold me it..................well, I dont want to get into it
Old Apr 7, 2008 | 01:56 PM
MarylandSpeed's Avatar
0MarylandSpeed
Former Vendor
We sell the SLP one..which I run on my own cars here-
http://marylandspeed.com/slp-160-deg...228-p-474.html
It is right around $30 shipped.
To 160 thermostat
