Front Tires Cupping on Inside
Old Apr 9, 2008 | 06:56 PM
Quick 06's Avatar
Quick 06
Default Front Tires Cupping on Inside
Just noticed that my front tires have significant cupping on the inside portion of the tread. Otherwise the tires look as good as could be expected for 14K miles. I don't have any vibration; however have significant tire noise from the front tires.
Can anyone tell me the type of alignment equipment I should look for at my/any dealer to ensure a good alignment. I figure I'm going to have to have the front two balanced and probably a four wheel alignment (although my rear tires are wearing well).
Any recommendation(s) would be appreciated.
Old Apr 9, 2008 | 08:30 PM
als2052's Avatar
als2052
Had my 4 wheel alignment at 14K...at dealer to buy some more time with tires...
Old Apr 9, 2008 | 10:31 PM
NORTY's Avatar
NORTY
Like this?
Old Apr 10, 2008 | 06:43 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
What tire pressure are you running?
Old Apr 10, 2008 | 05:00 PM
986_C6's Avatar
986_C6
Originally Posted by NORTY
Like this?
WHoahhhhh!!!!!!
Old Apr 10, 2008 | 07:03 PM
Quick 06's Avatar
Quick 06
Default Tire Pressure
32#'s when warm, starting with 30#'s cold, and I monitor it frequently.
Old Apr 10, 2008 | 07:19 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
You probably have some toe out. If you have the toe set to 0 you should not get that.
Old Apr 11, 2008 | 06:43 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Cupping is due to either an unbalance tire, bad shock or spring. The reason it shows the wear on the inside of the tire is due to camber which is an alignment issue.
Old Apr 11, 2008 | 07:52 AM
02magred's Avatar
02magred
Due to factory alignment.
Dealer will do 4 wheel alignment for under warrenty if car has less then 7500 miles
Old Apr 11, 2008 | 02:42 PM
ejbarre's Avatar
ejbarre
I recently had the same problem. I went to my dealer & the service advisor tried to tell me that it was normal. I asked to see the service manager, he was very helpful after I asked to speak to the service director. The manager called a Tech Advisor at GM, the Tech advisor said that the cupping was not normal & recomended to set the Camber at least .3 to .4 more positive, which they did. I will keep a close eye on the tires from now on. I hope this helps you.
Old Apr 11, 2008 | 04:38 PM
07MontRedcp's Avatar
07MontRedcp
BJK
Old Apr 11, 2008 | 05:17 PM
Quick 06's Avatar
Quick 06
Thanks for the information. That will definitely help. I'm going to take it to the dealer on Monday and will take your specs along to compare.
Old Apr 11, 2008 | 05:28 PM
QuickCorvettes's Avatar
QuickCorvettes
Default Corvette C6 Alignment Custom "QuickCorvettes" Set up
Here are settings that will give good performace to a C6 -Z51 car. These are my own custom QuickCorvettes settings. I have tested now on 2 cars, with no significant wear. Handling dramatically better. *This is not a recommendation but a good baseline to start from. If anything go less, not more, until the car feels right.
Cheers
Front set up
Caster 7.5-8.5 deg
Camber -0.6 negative camber, max -0.8 negative camber (car will rail nicely) above this tire wear very quickly. Ie. -1.0 will burn up the insides.
Toe 1/16 total toe out. Works very well.
Rear Set up
Camber -0.8 negative camber, max -1.0 with no tire wear
Toe 1/16 inch total toe in (minimal), max 1/8 inch total toe in (better for high speed stability)
I run 30-31 pounds at 4 corners cold. 28 cold for HPDE. GY Supercar Runflats.
Old Apr 11, 2008 | 05:46 PM
Modshack's Avatar
Modshack
Zero Camber is good if you drive like a grandma and put more weight on tire wear than good handling.....
If you drive the car like the factory expected you to, you'll get even wear. (and NO I don't mean as it comes off the line...I mean adjusted to factory SPEC which are often two different things..)
Old Apr 11, 2008 | 06:06 PM
Quick 06's Avatar
Quick 06
I hear you Modshack, my car gets driven seriously hard including a couple jaunts to VIR per year and the Burlington 1/8 mile when I want to try to break things.
A couple trips to Spring Mountain and another at the BMW advanced driving course near you taught me that these cars are a waste in the hands of grandma (now grandpa's ok!) and most Corvette club members that spend more time at parades than enjoying the capabilities of the car.
Hopefully getting my Vette adjusted back to factory specs and/or balancing of the front wheels will get me somewhere close to where they should be.
Hope to run into you one of these days on the roads of North Carolina...
Old Apr 11, 2008 | 06:15 PM
07MontRedcp
Hopefully, not head on.
BJK
Old Apr 11, 2008 | 06:25 PM
Modshack's Avatar
Modshack
You're even closer to the Mountains! (I'm jealous)... Headed out there in a few weeks for a little twisty fix...
Here's mine, before and after. factory settings were pretty sloppy, but as I've said before, they have 3 minutes to get those 10 adjustments into spec... ( ). Mines been working great and tires wearing perfectly...
To Front Tires Cupping on Inside
Old Apr 12, 2008 | 09:06 AM
AO-08's Avatar
AO-08
Default yes
for sure.
maybe shock like another poster says. You'd feel that i suspect.
Old Apr 12, 2008 | 02:05 PM
LPE385's Avatar
LPE385
These cars cup on the inside edge. This is just the way the set up is from the factory. I look at appox. 500 Corvettes a year and for the tires to start cupping in the mid teens for miles is totally normal. Sure a bad set up will cause it to be worse but this is something 90% of C5's and C6's do. I've seen coutless cars that the tires look perfect but the last inside edge is al most gone. These cars drive staight, no pulling nothing. I have seen a few cars that the tires were nice at 15,000 miles but they a few and far between. These tires are only really good for 20,000 miles so your appox. 75% gone.
Old Apr 12, 2008 | 04:49 PM
Mike V.'s Avatar
Mike V.
Default What about lowered cars?
My car is lowered max on front adjustment bolts, rears maxed plus cut 1/2 the bushing off. Just replaced the tires, all where shot but for different reasons. Rears worn evenly, but down to nothing from heavy right foot. Fronts, which is where I'm concerned, were worn to the cords on both inside edges at about 12-13K. I am looking specifically if there's different setpoints for a lowered '05 Z51. A happy medium between performance & wear is the goal. Thanks in advance for any suggestions.
