For those of you that have actually installed either or both, which one should I go with to mate up with the B&B Fusion, premised upon the following:Complete system to run the butterfly valve in the exhaust; andEasier to install; andPermits me to control the valve as I see fit and lets it operate at preset values if I do not want to touch the buttons.
I have the Sunset, top notch service 5 minute install. The NPP I haven't seen but Im sure it is great too.And both are great vendors.
as for the 2nd question. Mine gives you open or closed at start then.
I mounted my remote on the visor.You can open or close at will.
Hope that helped.
Sunset. Great little remote, easy install. And the option of open and closed at start.Once you here the open you wont need the remote.You can also pull the fuse, but i opted for sunshine.Put the remote in the cup holder.
