'05 c6 4 speed auto question
Old Apr 14, 2008 | 11:27 AM
lil red vette's Avatar
lil red vette
Default '05 c6 4 speed auto question
Am considering buying a '05 with the 4 speed auto trans. Was wondering if there were any problems with that trans. Would like some owner's feed back.
Old Apr 14, 2008 | 12:23 PM
dennis50nj's Avatar
dennis50nj
it seems to be fine their was a tsb about mis machined case
Old Apr 14, 2008 | 12:34 PM
Ponchorello's Avatar
Ponchorello
I have no problems with mine however you may want to stay away from the track with the A4. The differential case is one weak motha!
Dennis, didnt you get Cartek to swap out for the C5 case?
Old Apr 14, 2008 | 12:46 PM
dennis50nj's Avatar
dennis50nj
hi Ponch, nope i still got the stock case, all i got was the 373 and the 1 hardened output shaft. so far i been lucky, and hope it stays that way
Old Apr 14, 2008 | 01:18 PM
LS1LT1's Avatar
LS1LT1
This is true but fortunately the automatics tend to live a lot longer/better than the manuals.
Old Apr 14, 2008 | 02:53 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
I have had no issues with my A4. While I don't abuse it I have had it to the track twice with no issues. Wheel hop seems to be the biggest problem and that usually with the manuals, at least that is what I have read.
Old Apr 14, 2008 | 05:06 PM
Tire Guy's Avatar
Tire Guy
St. Jude Donor '08
40k miles and no problems on my A4...
The Tire Guy
Old Apr 14, 2008 | 05:41 PM
Vette_DD's Avatar
Vette_DD
Had a problem with getting the shifter out of park when sitting on level ground with my 05. Dealer eventually replaced the shifter.
Old Apr 14, 2008 | 07:46 PM
Vetteinplano's Avatar
Vetteinplano
36K and no problems with my A4/3.15
Old Apr 15, 2008 | 12:19 AM
jmess's Avatar
jmess
Track days aren't your friend with the A4. There is no rev matching when down shifting which can get really annoying and isn't the best for the rear diff either.
Old Apr 15, 2008 | 01:11 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
I have a 2005 A4 with 3.15 gears. Absoutely trouble free. I have taken the car to several 1/4 mile track rentals without any problems.
Unless you intend on materially increasing the horsepower the A4 as is will be fine.
Old Apr 15, 2008 | 03:43 AM
keyplyr's Avatar
keyplyr
'05 A4 3:15s, no issues for 20k miles.
Then, as a proactive measure, I swapped out the trans for a custom built stage5 A4 w/ hardened shafts since I increased HP and upgraded to 3:73s with stall converter.
Now 3k miles later, still no issues except a big silly grin that will not diminish.
To '05 c6 4 speed auto question
