how do I remove the dash corner pillars?
Old Apr 20, 2008 | 09:18 AM
TAILWAG's Avatar
TAILWAG
Default how do I remove the dash corner pillars?
I am trying to run the V1 cord from the passeger side through the dash/door pillar and can't figure out how to pop this thing out...I have searched and can't find any explanation or photos. Is it a simply "yank"? I don't want to break anything on my new car but HAVE to HAVE my V1 in place.
I already have my concealed display mounted in the ashtray and my hardwire kit by the ECU...but I need the longer wire to feed through the pillar I am mentioning.
Any help will be appreciated - thanks!
Old Apr 20, 2008 | 10:48 AM
LEAVINU's Avatar
LEAVINU
A solid yank will do the trick with no breakage. I have done the same on my C5Z and my current C6 for gauge pods and a/f meters. Never had an issue.
Pull from the very top where the mirror swivels from and you will hear it begin to pop out of the clips.
No sweat.
Old Apr 20, 2008 | 02:00 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
as you get to the bottom where it meets the dash be careful as there is a plastic hook that can easily be broken.
Old Apr 20, 2008 | 11:43 PM
spammark's Avatar
spammark
Post some pics when you are done.
Old Apr 21, 2008 | 10:00 PM
RFP's Avatar
RFP
St. Jude Donor '09
Old Apr 23, 2008 | 10:38 PM
cerino2000's Avatar
cerino2000
If you can, post pics of the back side of the pillar to give others an idea of where the clips are.
Old Apr 23, 2008 | 11:25 PM
MARSC6's Avatar
MARSC6
http://forums.corvetteforum.com/show...light=a-pillar
Old Apr 25, 2008 | 07:51 PM
TAILWAG's Avatar
TAILWAG
all done with this...I did not have to remove the A pillar completely to get this done - the top part just snaps off....the bottom, I was not so sure - but I was able to feed a coat hanger with the wire in between and pull if from under the dash...
To how do I remove the dash corner pillars?
