Opened up the C6-2008 Manual page: 5-97 Showing the fuse layout. The small box at the bottom of the diagram with 4-fuse/2-blank & the box at the far right with 16 fuses are not under the passenger side floor location ? Do you know where they are located ? The main assembly is all that is at that location. Thanks:
I guess the button isn't working. I know on mine I guess I didn't use the button enough so it got stuck and when I pressed it the button never came back down. So...just to be helpful, can you feel the button going in and out?
I had a bad button on mine too. They "Vette Tech" said I didn't use it enough so it started sticking. It would work like once a day. Maybe you could try taking it apart and blowing it out with an air compressor or that keyboard cleaner. Or if it is under warr. have them repl. it like I did.
