LS3 with NPP want to add headers
Old Apr 21, 2008 | 09:05 PM
FZovko's Avatar
FZovko
Default LS3 with NPP want to add headers
I want to purchase a set of Kooks coated headers for my 2008/Z51/6Sp.
Can I just buy the headers? or do I need to buy x-pipe, cats, anything else?
Old Apr 21, 2008 | 09:46 PM
nwc6's Avatar
nwc6
Your gonna need X-Pipe, and if you don't like raw exhaust/gas smell get the high flow cats. The OEM cats attach directly to the exhaust manifolds on the C6 so no way to attach them to headers..
Old Apr 22, 2008 | 12:44 AM
antimullet's Avatar
antimullet
7th Gear
If I wanted a true 3 inch header/dual exhaust all the way out the back for my 08 ls3 who makes one?
Old Apr 23, 2008 | 10:36 PM
cerino2000's Avatar
cerino2000
I don't know that there is a bolt on 3" for the LS3.
Old Apr 24, 2008 | 12:11 AM
FUNTRUN's Avatar
FUNTRUN
LG can set you up with a 3" system all the way through for your LS3.
Old Apr 24, 2008 | 09:43 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Any of the headers you buy will come with everything you need to install and connect to your mufflers, you do not need to buy a separate x-pipe. Typically, you can buy them with high flow cats or a cat-delete designed for off road use.
Old Apr 24, 2008 | 09:54 AM
haljensen's Avatar
haljensen
Most headers require 3 seperate sections (5 pieces); Left and right Long tube headers, left and right high flow cats (OR left and right cat delete pipes) and an X pipe. The header system will bolt to your stock and most aftermarket axleback systems.
To LS3 with NPP want to add headers
