LS3 / LS7 Based 427 - What are the Differences?
Old Apr 22, 2008 | 11:52 AM
throwit's Avatar
throwit
Default LS3 / LS7 Based 427 - What are the Differences?
With the LS3 using a 4.100" stroke and the LS7 using the 4.000", what would be the differences in each setup be (performance wise and dyno charts)?
Thx
Old Apr 22, 2008 | 04:08 PM
andreas g.'s Avatar
andreas g.
My LS3 with a 4.100 stroke yeilds 427 ci, The LS7 comes with a 4.000 stroke to give it 427 ci. Using a 4.100 stroke in an LS7 gives 440 ci
Old Apr 22, 2008 | 04:17 PM
throwit's Avatar
throwit
that wasnt exactly what i asked, but thanks for letting me know....
what would the performance differences in a 427 (ls3) vs a 427 (ls7) be?
Old Apr 22, 2008 | 04:25 PM
Keaka26's Avatar
Keaka26
Ever so slightly better rod ratios on the LS7 I'd guess...Which would translate to an engine that would be safer at higher RPMs...I think the difference would be pretty small, but I guess I could be wrong
Old Apr 22, 2008 | 05:43 PM
andreas g.'s Avatar
andreas g.
Thx
Performance wise and dyno charts: You would need to know more than just strokes. Cam size, head work, intake headers , tunning, etc. my LS3 427 made 525rwhp/500rwtq with a somewhat small cam, but had a lot of heads work done to the LS3 heads. There are all kinds of different paramaters to consider. I'm told that a 440 inch LS7 with head work and a small street cam can give as much as 580-600rwhp. for whatever that's worth. Again more info is need.
Old Apr 22, 2008 | 05:51 PM
1.8t's Avatar
1.8t
My buddies 440ci LS7 made 590whp w/ a medium size cam. Get ahold of Vengeance Racing, they built the car.
Old Apr 22, 2008 | 07:22 PM
Torkster's Avatar
Torkster
5th Gear
research engine stroke ratio. In theory, an ls3 should make more low end torque and the ls7 should (well it does) rev higher and make more power up top.
To LS3 / LS7 Based 427 - What are the Differences?
