Need Help! Removing stock C6 Exhaust Question
Old Apr 26, 2008 | 06:13 PM
Darwin11's Avatar
Darwin11
Default Need Help! Removing stock C6 Exhaust Question
Im replacing my Full stock C6 for stock Z06 exhaust.
How do you get the stock mufflers out? Cut them?
Thats what i did....
The Stock Z mufflers are welded muffler and over the rearend pipes.
Do you have to drop the suspension? What is needed to install the 3" Z mufflers with pipes?
If you guys could let me know the easiest way that would be great and thanks in advance.
Old Apr 26, 2008 | 06:19 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
I would definately not drop the suspention I would cut it somewhere I could make an easy joint later. hope this helps
Old Apr 26, 2008 | 06:45 PM
Nicodemus's Avatar
Nicodemus
You need to remove the rear anti rollbar. You do not need to disconnect the end links just the mounts and flip it down out of the way. This will give you enough room to get the mufflers in and would have given you enough room to get the stock ones out without cutting.
Old Apr 26, 2008 | 10:55 PM
blkc6z51's Avatar
blkc6z51
This should help you, good luck.
http://www.borla.com/media/installations/11746.pdf
Old Apr 26, 2008 | 11:43 PM
Darwin11's Avatar
Darwin11
Thanks Guys !
To Need Help! Removing stock C6 Exhaust Question
