Trick Flow Heads vs AFR
When I was in Florida I rented an 08 and after driving it for the week I am very happy on how much faster my car runs. It was the first time I had driven another vette.
Michael
Michael
I like to think I am pretty fast could use some more low end but its is what it is........
The heads are the TF 225 I do not know the part # on the rockers. I have a small cam 224 228
http://youtube.com/watch?v=FdBa44L_6b4
Between those two my choice went to ETP 215...
Why???
Because I took a look at the reality of the technical aspect and the best of both brands is on the ETP Heads.
- Valve angle is rolled to 11° on the ETP vs.13.5° on the TFS and 15° for the AFR.
The ETP is the only one who made a casting with the same characteristics than the C5R, GM can't be wrong with the 24 hours Le Mans winning C5, don't you think?
- On the ETP heads the valve-train geometry is PERFECT with the OEM rockers and valve the train deflection is non-existant...
I rev my engine to 7450RPM with zero valve float.
- The ETP deck is the thickest when you compare the two others vs. the ETP...
- The ETP heads are the only one to have INSERTS from the factory to "on the top of the thick deck" improve rigidity, very well engineered sirs!!!
- ETP Factory or any of their dealers can deliver you from the factory the exact volume chamber you or your engine builder wants...for the same price!!!
- On the ETP heads the Intake port volume starts at 215cc then 225cc then 235cc then 245cc...thanks for the choice.
- The price is similar to the AFR and less than TSF when you add to those the roller rockers.
- At the end those ETP 215 in my daily driver stock cube stock shortblock on pump gaz that is so drivable than my wife use it...is producing 511rwhp and 455rwtq... and cruise 1200rpm in six gear or 20mph in a school zone in third...enough say I guess.
Regarding racing, in the big dog world, ETP is used by the best, but if you are racing, you know that you never tell the others what makes you the fastest...no???
The only problem is that ETP is selling so much that they don't need to advertise and you may wait a little more to obtain them vs.the competition.
Christian
I would love to have either one of these heads
