Must Read For All Corvette Owners
G.M. is taking a position on this Document. G.M. Legal is denying warranty on a 505 H.P. Z06. The vehicle had Long Tube Headers etc./ Broken Piston, they are using cvn as the basis for no warranty. I'm told they are not backing down, this will be a test case to show how business in the future will be done. ( Warranty )
Bye,
Service Information
Document ID: 2094075
#PIP4386: Identifying Aftermarket Engine Calibrations - 2.0 2.2 2.4 2.8 2.9 3.0 3.1 3.2 3.4 3.5 3.6 3.8 3.9 4.2 4.3 4.4 4.6 4.8 5.0 5.3 5.7 6.0 6.2 7.0 7.4 8.1 - (Apr 8, 2008)
Models: 2005-2009 GM Passenger Cars and Light Duty Trucks
except Pontiac Vibe, Chevy Aveo, and All Saab Models
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A dealer may have the need to verify engine calibrations. If a dealer feels an aftermarket power-up calibration has induced engine and/or drive train damage, there is now a way to verify what calibration is currently in the vehicle. Subject: Identifying Aftermarket Engine Calibrations
If a suspicious hard part failure is observed in the engine, transmission, transfer case, or driveline, perform the calibration verification described to determine if a non GM issued engine calibration is installed. Non GM issued engine calibrations subject driveline components to stresses different than those that these components were validated to. Repairs to transmission, transfer case and / or other driveline components where a non GM engine calibration has been verified, are not covered under the terms of the New Vehicle Warranty.
Recommendation/Instructions:
Instructions for confirming Calibration Verification Number (CVN)
• Go to TIS2WEB
• Select Calibration Information (SPS Info)
• Enter VIN
• Select "Get Cal ID"
• Select ECM Engine Control Module
• Hit "next"
• Select "Complete History"
Take Printout to Vehicle along with Tech II
• Plug in Tech II
• Go to diagnostics and build the vehicle
• Select Powertrain
• Select the engine
• Select F0 - Engine Control Module
• Select F4/F5 - I/M information System / Module ID information*
• Select F1
• Compare the calibration ID and Calibration Verification Numbers (CVN) to the Calibration Verification Numbers (CVN) on the printout.
* This step may vary by controller; use the Module ID Information in the Engine Controls.
Although the part numbers will be the same for each, it's the CVN that will determine if the calibration is GM issued.
If ALL of the CVN's are EXACTLY the same, the calibration is GM issued.
If the part numbers match and ANY calibration verification numbers (CVN's) do not match the printout, it is likely that a non GM certified calibration has been installed.
In order to document the case - a CLEAR digital picture should be taken of the TECH 2 screen showing the VIN and the CVN's that do not match the TIS2WEB printout. The picture and a PDF copy of the TIS2WEB printout should be forwarded to jay.dankovich@GM.com for verification along with the VIN and the reason the vehicle is currently in for service. Please copy your GM Area Service Manager (DVM/DSM) on the e-mail. GM will verify if the CVN's are not GM issued and respond via e-mail within 48 hours.
If both the Part numbers and the CVN are different, photograph the part numbers and CVN's on the tech 2 screen as described above, assuring the VIN shows clearly in the photograph of the TECH2 screen, and check to see if the vehicle has the latest released calibration. If the latest released calibration is not installed in the vehicle, the part numbers will not match , and the CVN's won't either. E- mail the original Part Numbers and CVN's found in the vehicle on the TECH 2 to: jay.dankovich@GM.com to check if the calibration and CVN matches a previous release. Recalibrate with the latest released cal and re-check against the part numbers and CVN's that are released.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
I guess I'm on GM's side on this one. I owned a heavily modified C5. Burned a piston, damaging the block. Did I get warranty repair. Of course not!
Now, when you go to look at a "used car" or used Corvette, not only do you have to do a CarFax, but a "dealerFax" to see if the car's still legit in the eyes of GM.
It gets interesting, eh?
...the memo is old news.
People like to modify the cars - they JUST DO. If GM had any sort of a brain at all they would figure out what it would cost to offer a special warranty to cover certain modifications that are popular and rarely cause issues. I'm sure they could do this, and they could get A LOT of takers and more revenue.
Instead we have the "scare tactic" which won't rectify the situation, only irritate people and is a cost savings vs revenue generator.
I have a GMPP out to 84 months and I have modded the heck out of my car. I don't expect GM to stand behind anything EXCEPT those pieces that aren't involved with my mods.
http://forums.corvetteforum.com/show...post1564766871
"I just don't think you understand where I am coming from. I do understand what the original post was about. I stated I agreed with it, but that it was a shame it had to come to this because a stock Vette with a tune is safe and will not break anything."
http://forums.corvetteforum.com/show...post1564762949
"Until someone can show some proof, I stand by my statement that a tune only on a C6 is very safe if a reputable tuner is used. The sky is not falling people."
Of course comments like this one below, from gonzalezfj, mean nothing to people who embrace the above ideas.
Good luck with your mods. You are obviously an honest man. They are getting fewer and fewer these days, it seems.
Frank Gonzalez
In the end, GM's position was justified as it turned out to be a detonated piston caused by external circumstances.
You play you pay.
You play you pay.
You play you pay.
Couldn't agree more.There are some on this forum, who believe that they can add every bolt on to their cars, and tune them and expect to have no warranty issues.
"In the end, GM's position was justified as it turned out to be a detonated piston caused by external circumstances."
Good thing you didn't blow money on a lawyer attempting to beat them over the head with the Magnusson Moss warranty act.
You would have lost.
