Can you tell me how we can find out if i have gps antenna on 2006 3 lt xm radio bose hud i at the dealer and everything is apart and we can<t find any antenna thank you.
I am trying to install a nav unit
If it is there, it is under the dash pad over the left hand HVAC duct. It is held in with two plastic rivets (push pin). The service manual says to remove the instrument panel (dash pad) - yech! You should be able to see it if you remove the instrument cluster bezel. The manual shows a single coaxial lead from the antenna. If you don't already have the nav radio, there is little liklihood that there is an antenna in waiting, though the service manual doesn't say one way or the other.
Thank you very much for your help no antenna had put everything back
Sorry I didn't get to the thread this afternoon. As you saw, the email during the day is the best way to reach me. Sorry this one didn't work out for you. Now you know what to expect.
If you decide to go for it. Here is the pricing on the antenna from Gene at GMPartshouse:
