Front end Alignment
Old May 1, 2008 | 04:14 PM
ROD BROWN's Avatar
ROD BROWN
Default Front end Alignment
I am replacing my tires for Michleins tommorrow and does anyone know what the alignment for the front and rear should be set? Thanks,Rod
Old May 1, 2008 | 04:17 PM
johnodrake's Avatar
johnodrake
Moderator
Try these:
File Type: xls
Old May 1, 2008 | 04:31 PM
andreas g.'s Avatar
andreas g.
Don't know, but had my car aligned front and rear at Bells Auto works, there by the john Wayne airport in orange county. These guys do all the high end cars in the area. They set my car up perfectly, after i hit a truck tred and damaged the Rt lower control arm. They also replaced my front bumper perfect match in paint.
Old May 1, 2008 | 04:58 PM
ROD BROWN's Avatar
ROD BROWN
Default Thank you
Thats the info I needed.Thanks again.Rod
Old May 1, 2008 | 05:17 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
There is no simple answer. Depends on your intended use and desires. Do you want best handling for autocross, minimum wear, best straight line performance, etc?
You need to decide and tell your alignment guy exactly what settings you want.
Do a search and spend the time on the research.
Old May 1, 2008 | 05:44 PM
Aaron Pfadt's Avatar
Aaron Pfadt
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
We have an alignment guide available on our website. It tries to give suggestions for different car uses.
Alignment Guide
For track use, there is no substitute for testing.
-Aaron
Old May 1, 2008 | 07:45 PM
danl72's Avatar
danl72
Thats great info. It will come in handy. Thanks.
Old May 2, 2008 | 02:42 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Alignment Guide
-Aaron
Your Pure Street camber seems a bit high for pure street. What do you mean by pure street? Are you saying that interstate driving and downtown and city driving should be at the camber numbers you show -0.8 front and -0.5 rear? Stock camber for the C6 coupe/convertible is -0.45 front and back. That amount still wears out the inner edge of the tire and there have been MANY threads in this forum showing some thread bare tires from stock settings. To get the best mileage out of the tires, I run -0.1 on the camber front and back. Granted, this is not the best setting for any kind of "twistie" driving but for straight street driving and interstate, the lower camber will give the longest tread wear for our tires. I'm very surprised at the high values you show on "Pure Street". I have no issues with the other three camber settings as you are using the camber to give agility in the turns.
Elmer
Old May 2, 2008 | 03:40 PM
scottycards's Avatar
scottycards
St. Jude Donor '08 thru '13
Originally Posted by johnodrake
Try these:
Interesting. Factory spec on the fronts is actually toe out.
I would have never known this.
Mine is going in Tuesday for alignment, and I'll take this spec sheet with me.
Thank you for posting.
To Front end Alignment
