BFG KDWII's - Noisy?
Old May 2, 2008 | 02:17 PM
kharyespy's Avatar
kharyespy
Default BFG KDWII's - Noisy?
Can anyone speak to the road noise rumors I've been hearing about these tires? I have read many threads regarding new tire choices and am still at a loss.
Old May 2, 2008 | 02:45 PM
cody6.0's Avatar
cody6.0
I ran some KDW II's on my 2002 Camaro SS and didn't think they were what I would call loud.
Old May 2, 2008 | 03:57 PM
mikesul's Avatar
mikesul
I've had two sets on my last two vettes ('06 & '08) and found them a heck of a lot quieter than the RF's. The performance difference would be worth it even if they were louder, but they are not.
Old May 2, 2008 | 04:22 PM
Mike V.'s Avatar
Mike V.
Default What noise?
I'm w/ the other guys, I don't think they're particularly noisey. You notice differences on different pavements but still quieter than, smoother, better traction, hell in every way except being non-runflat than the original GYSCRFs. I am very impressed & satisfied with these tires & both recommend & would purchase again.
Old May 2, 2008 | 05:34 PM
DarkMastyr's Avatar
DarkMastyr
I've heard some conflicting things about KDW2's... people here say they're not too noisy, but I have a couple buddies with S4's that will attest that they're noisy as hell. One GAVE his set away because he couldn't stand how noisy they were.
Old May 2, 2008 | 07:00 PM
zonie's Avatar
zonie
FWIW, I replaced the OEM RF's with these and they are not noisy.
Old May 2, 2008 | 08:33 PM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
Definitely not noisy, great tires, MUCH better and quieter than the run craps.
Old May 3, 2008 | 12:38 AM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
No no and no..Please stop it with all this road noise myth and kdw2's. Road noise comes from the surface you drive on. I have them for 2 years now...what road noise? Plus I have headers, full exhaust, cam, 4.10 gears, vortex ram air, fast 90 intake..ok I am worried about earth shattering road noise with KDW2's..
They are awesome up to 450rwhp for the street..After that you need slicks or drag radials for optimum traction.
Old May 3, 2008 | 08:40 AM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
I've had them for a couple months now and they are great. I don't know what everyone's complaint is about noise because I have none. They hook up so much better than run craps that I would run them even if they were noisy.
Old May 3, 2008 | 09:19 AM
Walt White Coupe's Avatar
Walt White Coupe
10,000 miles on mine and they produce less noise than the original supercars. Noise is mostly dependent on type of road surface. Old concrete is the worst.
Old May 3, 2008 | 09:24 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Not to hijack, but how is the car doing, Phil? Hope you're doing very well and having fun!
If you are saying the KDWs are hooking with all that new power, the mild mod guys should not hesitate....getting traction will feel like more TQ for sure.
Old May 3, 2008 | 11:34 AM
Mike02z's Avatar
Mike02z
Hard to tell noise when you have a GMMG exhaust. I run these on my Camaro.
One isssue I have had is the beads not sealing properly. Your tires will seem fine and then you'll go out and find a flat. You'll take the tire to a tireshop and they will tell you nothing is wrong with the tire. I had this happen 3 times on 3 different tires. I then researched it and found many people have the same issue. Now I just pump the tire back up and go on my way. Google "KDW2 sealing issues"
Good luck!
-Mike
Old May 3, 2008 | 01:56 PM
G Alex's Avatar
G Alex
I had a BIG problem with beading issues. I had new rims and they couldnt get the tires to seal, 2 of them anyway. I had bead sealer on the and it was insane. I would come to the garage and two would be dead flat. I bought a pump for that reason. They were loud on my car. I know others say not but tire noise drives me insane and these tires were loud. I have had lots of cars,tires and these TO ME were loud. Initially they were fine but with a few miles on them they got loud. They finally got so loud, I gave them away and went to another tire. I see lots of guys that have no problems but it may come down to mods, hearing, and what roads you drive on. Personally, I wouldnt buy them again. The beading issue absolutely drove me insane. The first time, they said there must be some rust in the wheel causing it. Wrong. Spanking brand new oem rims. You could lick the inside and not taste anything. The second time they bead sealed it with the glue stuff, it was on the edge of the rim, took some time to clean. I thought that would be it but after some driving, I guess the bead slipped a bit and I would come out with two flat tires. The noise was present to me. FTR, I am in my 30's and noise usually doesnt bother me. Maybe I got a bad set as the noise levels seem acceptable on tirerack.com from the reviews. They did look great and handled really well .
Old May 3, 2008 | 02:09 PM
Revving High's Avatar
Revving High
had them on my cobra. I thought they were noisy.
Old May 3, 2008 | 02:34 PM
SavannahVette13's Avatar
SavannahVette13
i just got them put on 1 month ago, i love them! they are a lot smoother than the goodyears...i def recomend them! they hook up pretty good also
Old May 3, 2008 | 04:01 PM
robbiC5's Avatar
robbiC5
No noise, awesome grip.
Old May 3, 2008 | 04:33 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Are you guys going with stock sizes or +1? Those of you with beading issues. Were they mounted on stock or aftermarket rims?
To BFG KDWII's - Noisy?
Old May 3, 2008 | 09:01 PM
10mikeymike's Avatar
10mikeymike
Default BFG's
I was one of the guys who was complaining about the noise. At first, I was going to sell them and go with something else. Now, I don't think they're any noisier than the Goodyear's they replaced. In addition, the ride and handling is light years better than the Goodyear's. I think my problem was that I put them on the car in November and didn't get to drive it much. I think it was more an issue of the cold convertible top amplifying all of the externals sounds. This included wind, other cars, road noise, etc., Now that the weather has warmed up, I don't think they're noisy at all. I'm glad I didn't sell them. They look great, ride great and handle great as well. I have 275/35-18's and 295/35-19's on CCW SP500's
Old May 3, 2008 | 09:27 PM
G Alex's Avatar
G Alex
[QUOTE=k0bun;1565298518]Are you guys going with stock sizes or +1? Those of you with beading issues. Were they mounted on stock or aftermarket rims?
Mine were mounted on stock, NEW oem manufacturer rims. Maybe just me but they wouldnt keep air in two of them for @hit
Old May 3, 2008 | 09:50 PM
Danny318's Avatar
Danny318
I dont recommend them. They seem to like to fall apart
that one is the worst, the other 3 all show signs of missing pieces, chunks of rubber missing, and cuts in the tire.
http://72.93.251.3:8080/tirefail/
