Computer reset??????????? Help!
Old May 2, 2008 | 08:16 PM
Darwin11's Avatar
Darwin11
Default Computer reset??????????? Help!
Just needed to know how to reset my computer. Dealer?
Let me know!
Thanks in advance!
Old May 3, 2008 | 12:02 AM
runutzzzzz's Avatar
runutzzzzz
What are you trying to do?
Old May 3, 2008 | 12:14 AM
Darwin11's Avatar
Darwin11
It pulled a misfire code and need to reset the computer.
Changed exhaust and cracked a plug. Misfired and between trying to find it there was a check engine light on.
Need to reset it.
Dealer clear the code?
Is there a way without the dealer?
Thanks for the help!
Old May 3, 2008 | 12:22 AM
tmak26b's Avatar
tmak26b
autozone
Old May 3, 2008 | 08:43 AM
runutzzzzz's Avatar
runutzzzzz
Originally Posted by tmak26b
autozone
Almost any parts store has a obd reader.
Old May 3, 2008 | 08:51 AM
patton's Avatar
patton
St. Jude Donor '09
did you try a batt. disconect
Old May 3, 2008 | 09:37 AM
Darwin11's Avatar
Darwin11
Thanks guys!
I will try Autozone and a battery disconnect. I was told the disconnect would not clear it though.
Old May 3, 2008 | 09:48 AM
NEV3R L8's Avatar
NEV3R L8
You have to leave it disconnected for a couple hours I think for it to work...could be wrong though.
Old May 3, 2008 | 10:33 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
If you already corrected the problem just go somewhere where they
have a scan tool. Clear the code and you are in business again.
Old May 3, 2008 | 10:39 AM
C6~Missle's Avatar
C6~Missle
after a certain amount of start and stop ignition cycles, the system should reset itself. I think it's something like 15 times..
Old May 3, 2008 | 08:26 PM
Darwin11's Avatar
Darwin11
Great!
Thanks Guys for all the Help!
Old May 3, 2008 | 10:32 PM
johnodrake's Avatar
johnodrake
Moderator
You can get a OBDII CAN Bus enabled scanner for about 60 bucks or so. Good tool to have since you can't pull the codes in a C6 from the DIC.
Amazon.com has a bunch....
Old May 3, 2008 | 10:56 PM
danl72's Avatar
danl72
Old May 4, 2008 | 11:11 PM
Darwin11's Avatar
Darwin11
Thank you for the help.
To Computer reset??????????? Help!
