Installing Z06 Brakes
Old May 3, 2008 | 05:49 PM
NYC6's Avatar
NYC6
Default Installing Z06 Brakes
I just orderd CCw 505a wheels and have a connection for front Z06 calipers and rotors. Im just doing the fronts because I dont want to do the wide body conversion. I'll be painting the stock rear calipers. My question is, Who has the best stainless steel cables for the front swap? And should I swap the rears to s/s at the same time? Thanks
Old May 3, 2008 | 06:24 PM
EuroRod's Avatar
EuroRod
You can easily install Z06 brakes without the necessity to do a wide body conversion. All you need are wheels with the correct offests.
Old May 3, 2008 | 06:46 PM
runutzzzzz's Avatar
runutzzzzz
I got me SS lines from LAPD. You get all 4 but you can still install the rears with the stock rotors.
To Installing Z06 Brakes
