rear main seal leak
thanks
o and yeah rtv'd the corners
thanks
It works for me. I could care less what the forum mechanics think. With blown motors it's even more important to have neg pressure in the crankcase. I know it looks right to have the seals in backward the way the lip is but it doesn't work. Put it in the way GM says and simply create neg pressure in the crank case. I've herd from some that you can actually suck air pass the seals into the crank case with high neg pressure, how high I don't know. My LSA is 112 so at idle my vacume isn't very high. Maybe that's why I haven't had any problems in over 12,000 miles with my set up. A&A corvette did my forged motor give them a call and talk to Andy green. I'm sure he can help.
i suspect you've got too much pressure and not enough vent.
try opening up the 'pcv system' a bit. i'd be tempted to open up the 'fresh' air vent and the pcv outlet (into a catch can, of course
) . that should help get more 'flow' through the pcv system. if you build too much pressure you will blow. same thing happens when there isn't any pcv flow or vent cap. the engine continues to build pressure until there is relief. if there isn't a 'pressure release' the seal, which are weakest fresh, blow/leak.
i'd put her back together and try her with either a 'vented oil fill cap', or a larger flowing pcv system.
thanks
