Stealthy Cam For A6 ???
Old May 6, 2008 | 05:43 AM
TaShOo's Avatar
TaShOo
Default Stealthy Cam For A6 ???
A freind of main has Corvette C6 2006 A6 and he wants to buy a Stealthy cam.
what is the best Stealthy cam for it ?
Old May 6, 2008 | 09:12 AM
xstang's Avatar
xstang
I ran the Thunder Racing Cheater cam in my 05 and it was awesome! I was very happy with it. It behaved like stock but had a very awesoem powerband. My dad is still running it in his car and it traps around 125mph.... It Idles like stock and you do not lose any low end...
Old May 6, 2008 | 09:22 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
My cam is a 228/232 and I love it!
Give Dan at Livernois a call!
Old May 6, 2008 | 09:41 AM
Wallacefl's Avatar
Wallacefl
how much power do you feel the CHEATR was worth versus the LS2 cam excluding your other add ons eg: headers ,etc....Thunder Racing does not have a dyno comparison for this cam on their site
Old May 6, 2008 | 10:14 AM
xstang's Avatar
xstang
Here is what I recall.. It's hard to say how much it added because when you do other mods it changes...
It's been a real long time, but this is the breakdown as I remember it.....
Stock 345
Honker 357
AFR Heads and Cam 392
Headers 421
fast w/Shaner TB 446
Keep in mind the area under the curve... Look at the RWTQ down low.. This combo performed better than the numbers indicate...
Old May 9, 2008 | 05:07 AM
TaShOo's Avatar
TaShOo
thank you
give me more informaition about other cams
Old May 9, 2008 | 06:55 AM
racerx8's Avatar
racerx8
LPE GT11 is a great cam for the A6, check with Lingenfelter for fitment.
My '07 C6 A6 w/CoW 3:15's modded coupe has this cam, great power.
Old May 9, 2008 | 10:17 AM
Ragtop 99's Avatar
Ragtop 99
what other mods does he have? If he has headers, a 224/224 116 will be stealthy and have a wide power band
Old May 9, 2008 | 11:21 AM
RWSjr's Avatar
RWSjr
works well with my '05 A4.
Old May 9, 2008 | 11:42 AM
mikesul's Avatar
mikesul
I have the GT-11 in my '08 MZ6 and it idles @ 725 rpm with a Chuck CoW tune. Great power and, although I have headers and Corsa Sports, doesn't sound like a cammed race car.
Old May 9, 2008 | 12:51 PM
HawaiiC6's Avatar
HawaiiC6
I will be installing my Comp Cams XR275HR which is a 222/224 with a 112 lsa in a couple of weeks will let you know how it is.
Old May 10, 2008 | 01:42 AM
craftfox's Avatar
craftfox
i have that comp cam in car now,, it idles well, and drives like stock as soon as you come off of idle. it made 440 with patriot heads and stock intake. headers to.
Old May 10, 2008 | 09:22 AM
Wallacefl's Avatar
Wallacefl
I wish THUNDER RACING and LINGENFELTER would step up to the plate and publish some comparison numbers of their CHEATR cam and GT11 cams versus either or both the LS2 and LS3 stock cams. As a thought, I read an article a few years back in which the Chevrolet corvette engineers actually divulged that the at that time LS6 2002 cam(same as the LS2) only gave 8-10 hp away to the LS6 2004 cam and that cam without headers probably gave little away to their HOT cam with 215/230 duration. THe LS3 cam is essentialy the LS6 2004 intake lobe added to the LS2 exhaust lobe ....so maybe worth 5 hp over the LS2 cam itself...other thoughts = usually when you change rocker arm ratio from say 1.7 to 1.8 on an LS2 which is like adding 0.05 of lift and a couple more degees of duration...you get about 10-15 hp...you can see that changing to a CHEATR or the even higher lift GT11 would be like going from 1.7 to 1.9! ...very tough on springs...sure you can go to the cams with greater tha 220 intake duration but if your car is a daily driver pay attention how much of the time your motor is actually driving the car between 800-1500 rpm with an A6 transmission,..220 even with a good tune is going to BUCK some and maybe alot...of course with a wider LSA (116 or greater you might not notice it too much)...I have driven an LS7 and it idles wonderfully but just look at its cam specs including it's higher RAR and you would wonder how it could put out the power it does...come on cam manufacturers ...let's see some graphs/comparisons.
Old May 10, 2008 | 09:51 AM
Ragtop 99's Avatar
Ragtop 99
TR published results when they first came out with the cam. Their margins aren't big enough to give the cam away to test in each new application. It will do fine in an LS2 or LS3 and make more power.
The thing to remember is that the CheaTR is a small cam. If you want more power with stock manifolds, either up the intake duration or bring down the LSA to 114.
A 220 cam isn't going to buck when tuned. 220/220 114 cams were going into LS1s when tuning wasn't available and there was barely any bucking.
The low idle speed for an A6 with a stock torque converter is the primary limitation on cam selection.
Old May 11, 2008 | 09:53 PM
craftfox's Avatar
craftfox
omp 222-224 does not buck AT ALL.. tuned it still gets 25 mpg's also.
Old May 11, 2008 | 10:48 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Thanks but.......
Thanks Mike.....
As nice as your car runs.......
THE BEST CAM FOR AN A6 is MY 3.42 TOTAL ATTACK PACKAGE REAR END!!!
That's BEST mod for the money and it'll idle like stock and still get great mileage!
I LOVE REARS!
Chuck CoW
Old May 12, 2008 | 02:15 PM
Zach@MTI's Avatar
0Zach@MTI
Former Vendor
I'll see if I can dig up some stealth II A6 dyno sheets. You'll see a solid gain with no change in sound or driveability!! You can check out prices on our website and we always have them in stock and ready to roll...
Zach
To Stealthy Cam For A6 ???
Old May 12, 2008 | 04:19 PM
knkali's Avatar
knkali
Zach,
I am confused. Your web site says that no advance is built into these stealth cams for good low end power. I though advancing the cam is a way of getting low end power.
Old May 12, 2008 | 10:55 PM
knkali's Avatar
knkali
ttt
Old May 13, 2008 | 02:25 AM
TaShOo's Avatar
TaShOo
thank you for all answers
about the MTI stealth II and cheater I have tried them.
I know that lingenfilter GT11 is a good cam but i'm wory about the A6 transmition.
advaice me please cuz he will order a cam this week ?
