is this normal
Old May 6, 2008 | 04:44 PM
bigdan3419's Avatar
bigdan3419
Default is this normal
have an 2008,750 miles,shifting is not smooth until temp gets to 190-200,after it gets warmed up its shifts nice an smooth,should i take it to the dealer,thanks for the help
Old May 6, 2008 | 05:27 PM
JJC5's Avatar
JJC5
It's normal. When the fluid in the trans is cold, it's thicker. After it warms up, it flows much better and the syncros come up to speed faster which make your shifting much easier. Just double clutch when cold for a while.
Old May 6, 2008 | 05:40 PM
andreas g.'s Avatar
andreas g.
Give it some miles a few thousand and it will be smooth all the time. Gear faces and syncros need some miles to wear into each other.
To is this normal
