Quote:
Whatever I'm using for the brakes. Most advertise they exceed DOT 3 and 4. I track my car, so it is usually a 500 deg + dry-temp fluid. Many swear by Motul and the like, but they're a bit pricy if you're changing it often. I've used Valvoline V-Syn successfully and I have Johnsen's synthetic in right now, both relatively inexpensive. I'm told that the blue oval (Motorcraft) makes a really good, high-temp, cheap synthetic fluid. May give that a try. Good luck. I'm interested in hearing the experts myself . . . Originally Posted by journeyc6
It's time to change my clutch fluid, I know how to doit, the question is what fluid is the best to replace the factory fluid???
FM
Don't use DOT 3. Only use DOT 4 brake fluid for the clutch.
I use Prestone DOT 4 ($5 for 16oz bottle). You can buy it any AutoZone or O'Reillys. You have a number of brands to choose from. I'd stay away from the GM brand. Not cause its bad, but cause you get a 12oz bottle for like $12-$14. Might as well get more for you money using another brand.
ExploreI've been using the Valvoline synthetic; seems to work fine and its fairly cheap and easy to get. As far as I can tell good fluid changed
frequently is probably better for this application than great fluid not changed so frequently.
johnodrake
Moderator
close
- Member SinceDec 2002
- LocationLakewood Ranch, FL
Liked:4,326 Times in 1,895 Posts
Motul RBF 600 Clutch and brake...
I believe that wilwood is the same thing.
Quote:
Numerous track days with Motul in my C6.
Never let me down.
Same here. Was flawless with changes before and after each track event since new....until I put in a cam. Then I had to remove the pedal spring or the pedal would hang down after 1-2 shift. Without spring it works fine, though after the run it feels spongy - works, but feels spongy until I pump it many times on the return road.Originally Posted by LOS ANGELES PI
Motul 600Numerous track days with Motul in my C6.
Never let me down.
BEZ06
close
- Member SinceJan 2005
- LocationDaytona Beach FL
Liked:852 Times in 602 Posts
Originally Posted by HAIL THI$
Don't use DOT 3. Only use DOT 4 brake fluid for the clutch. I use Prestone DOT 4 ($5 for 16oz bottle). You can buy it any AutoZone or O'Reillys. You have a number of brands to choose from. I'd stay away from the GM brand. Not cause its bad, but cause you get a 12oz bottle for like $12-$14. Might as well get more for you money using another brand.
Just like Ranger advocates, I use Prestone DOT 4 in the clutch.
I use Motul RBF 600 for the brakes.
Bob
I use Motul RBF 600 for the brakes...
