NPP Converstion
How hard would it be to do the converstion and would it be a better idea to get an aftermarket exhaust? Also, is this system just the mufflers with the assoicated hardware to open the bypass valves or is it a whole cat back with bigger pipes? Thanks.
NeoTrunks
NPP in the box (self contained system to run NPP on any C6) installed in 10 minutes, the guys at his shop were blown away that a car could sound like this. Craig set it to start up with the flaps closed (a simple flip of the switch and you can change it to start open) but when he opened them and hit the gas while I was setting up the camera, I almost went deaf, thanks Craig.
Here is a video I did with my still camera (so it's not great), will take time to load (I can not emphasize enough that you need to turn up the volume and you need a good speaker system (with bass) or a good set of headphones). I have the bose II on my PC and my cabinets shake in the wild mode.
Notice how the inner flaps open and close
Play Video
Here is a repost of Craigster05 post in the tech section
NPP Mufflers waiting for Install
Factory Exhaust Removed
Drilling a ¼” hole in the rear well
Run the Vacuum Tube though the hole
Run the Vacuum tubes through existing frame locations
After dropping the rear sway bar, snake the NPP mufflers up and over
Attach the pipes to the mufflers
Connect the vacuum hoses to the NPP mufflers
Make sure your muffler pipes are straight and level
Muffler hardware done and vacuum tubing run
Locate vacuum nipple in well
Place NPP controller in bottom and attach vacuum and power lines
Place lid on top, you can still store items here (Does that look perfect or what???)
Connect power cable to the Seat Heater Fuse
And of course, a quick run with Ed's Polishing kit
That's all there is to it.....All that's left is to go out there and have a blast with your new found customized sound.
NeoTrunks
The picture shows power take off at the seat heater fuse. The full instructions are on my web site. I always post the full instruction so you can see whats involved. www.nakidparts.com
PS what makes you think my parts would fail, when you do things right you have no issues. The only part your are missing is my pump and it's rated for 20,000 hours of constant use and only see a few seconds of operation per day.
I can easily hear the pump run when sitting still or if I'm on a smooth road and under about 30 mph. I actually don't mind hearing it, because if there is a leak, it will run often.
Funney i quess thats the second time he now heard it makes some noise.Both are a good deal but i think $150 sunsetorangecreations with less parts is a better deal for people doing there own install.If the chevy z06 and npp,and B&B use engine vacume thats telling me something!
It's your choice, but since you don't have my system you should stick to what you know and have
You want to push your friends system fine, just don't do it by trying to but mine down
If we are picking out all the details, why do you recommend the B&B system with the Fusion? I don't see how the control system and mufflers are related. Either one will work together exactly the same.
