K&N filter problem
Old May 7, 2008 | 12:27 PM
pcolarossi's Avatar
pcolarossi
Default K&N filter problem
I was informed recently about a possible problem with the K&N filter systems. It seems that the oil used on the filter can get into & cause problems in the induction system. Has anyone heard about this possible problem.
K&N says there is no problem.....
Old May 7, 2008 | 12:33 PM
Buffy's Avatar
Buffy
If way too much oil is used when re-oiling the filter after cleaning it can get on the itty-bitty wires in the MAF and cause them to read incorrectly, causing a code. They are a real pain to clean, too.
Not a problem as long as the proper amount of oil is used (it doesn't take much).
Old May 7, 2008 | 12:36 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
a lot of people seem to think you need to get the filter dripping wet with oil = yes you will have a problem.
Old May 7, 2008 | 01:05 PM
danl72's Avatar
danl72
Doesn't take much oil.
Old May 7, 2008 | 03:18 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Yes. Too much oil and not waiting long enough for the oil to soak in are known issues. Some forum members even reported too much oil on filters from the factory.
Old May 7, 2008 | 03:29 PM
VET4LES's Avatar
VET4LES
All washable oil filters will cause a problem if too much oil is used.
Old May 7, 2008 | 08:53 PM
Modshack's Avatar
Modshack
Yup.....I've built and sold over 1000 K&N based Airbox systems for Audi's and VW's which also use a MAF based metering system. Never an issue until an owner gets a little exuberant with re-oiling at the first cleaning..
Old May 7, 2008 | 11:49 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
As a matter of fact, straight out of the box, a brand new K&N filter LOOKS like it's over-oiled in my opinion. It MAY NOT be, but it sure looks close to "dripping" to me.
Simple solution is to let it sit out a bit in a non-dusty, direct sun on some newspapers. I do that (or used to when I had them) as a part of my shaking out/washing/drying/re-oiling/drying process for these filters. Worked great; never had a problem with about a dozen or so of them over 20 years. Mine looked dryyyyyyy.....
To K&N filter problem
