Fully Built A6 Transmission!!!
Old May 9, 2008 | 02:51 PM
xcessivex's Avatar
xcessivex
Default Fully Built A6 Transmission!!!
ITS ALMOST HERE!!!
http://www.hptuners.com/forum/showthread.php?t=17393
Old May 9, 2008 | 07:15 PM
Superstock1200's Avatar
Superstock1200
I almost forgot I made that thread. Guess I should keep checking back. I plan to build my tranny and rear for fall, I hope.
Old May 10, 2008 | 02:39 AM
LS1LT1's Avatar
LS1LT1
Originally Posted by fafnir
its not "almost here"
they're saying a "couple of weeks"
that could mean ten in Chris@HPTuners or Bill@HPTuners speak
we all know they're "getting there" and they keep showing screen shots and parameter descriptions for the shift profiles and the fluid measurements and the fluid pressures and all the magical stuff that needed
but they've been doing so for a LONG time too - since 2006 to be exact
and no, this is not the same thing as shifting speed or line pressure or even trans behavior
this is more like "how do we hide the limp mode or make the error codes go away" when the clutch rings get replaced with something better than mild steel plated with a friction material
they do that and then someone like RPM transmissions is still proally going to take weeks to find out what all the parameters actually do to a trans
if not years
and remember, hptuners only gives the means to do so, but its still going to take a trans company to implement
that why i said "there is a pot of gold at the end of the rainbow"
i didn't mean that the rainbow is almost over, i meant its something concrete in existence that is actually quite abstract in when it shall come into existence
and every time it always feels so close you can smell the gold
and i've been waiting since the last two cars i had
and no, efilive and chuck cow won't be of any help when it comes to this
To Fully Built A6 Transmission!!!
