Bad O2 sensor?
Old May 12, 2008 | 10:36 AM
m_LeDez's Avatar
m_LeDez
From: Houston, Tx.....'05 Corvette M6 LS3 Magnuson Heartbeat
Default Bad O2 sensor?
I get a check engine light this weekend and my DashHawk shows 2 codes. Can someone tell me (from the codes) if it's the front or rear O2's?
P0136: HO2S Sensor Circuit Malfunction (HO2S-12).
--Description-- The downstream HO2S sensor(s) are continuously checked for maximum and minimum voltages. The test fails when the voltages fail to meet the calibrated limits.
--Possible Causes--
- Pinched, shorted, and corroded wiring and pins.
- Crossed sensor wires.
- Exhaust leaks.
- Contaminated or damaged sensor.
P0156: Heated Oxygen Sensor Circuit Malfunction (HO2S-22).
--Possible Causes--
- Shorted HO2S-22 Signal Circuit.
- Open HO2S-22 Signal Circuit.
- Open HO2S-22 GND Circuit.
- Exhaust leak.
- Damaged HO2S-22.
- Damaged PCM.
Old May 12, 2008 | 10:54 AM
patton's Avatar
patton
St. Jude Donor '09
i,m looking at my 07 shop manuals and they dont show those #,s
Old May 12, 2008 | 11:07 AM
haljensen's Avatar
haljensen
'05 Manual says;
P0136 = Bank 1, sensor 2 (drivers side, back sensor)
P0156 = Bank 2, Sensor 2 (passenger side, back sensor)
Old May 12, 2008 | 11:32 AM
patton's Avatar
patton
St. Jude Donor '09
i dont know why gm has to do that .the c5 codes stayed pretty much the same the whole run
Old May 12, 2008 | 11:38 AM
m_LeDez's Avatar
m_LeDez
patton/haljensen, thank you both for the response. I should have mentioned it was for my '05.
haljensen, if it's the rears, that's good news for me. I have a set of Nexus gauges w/ a A/F wideband. The original rear O2's were removed and replaced with the provided wideband sensor for one side and a plug for the other.
I recently had some work/re-tune performed and the rear O2's must not be disabled (I hope). My friendly dealership parts department want ~$100 per O2 sensor!
Thank again guys,
To Bad O2 sensor?
