New Tires??
Old May 12, 2008 | 11:42 AM
LAZLOW's Avatar
LAZLOW
Cruising
Default New Tires??
Who else out there makes a good run flat for our cars? I want to run wider tires on my C6. Can anyone help?
Old May 12, 2008 | 07:21 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Do a search.
Firestone makes the Wide Oval specifically for the Corvette C6. Its a run flat but does not have the same sidewall stiffness of the Goodyear. To compensate, I run them at 34 psi cold which gets to 37 psi hot.
Very quiet and street traction is good. I would recommend them for people who still want run-flat tires.
Old May 13, 2008 | 04:17 AM
keyplyr's Avatar
keyplyr
If you can wait a bit Michelin will have their new Pilot runflats (seen on the ZR1) on the market sometime this summer.
Old May 13, 2008 | 10:31 AM
Duke/Earl's Avatar
Duke/Earl
I have had the cold 30 psi go up to 39 psi. It was over 100 degrees in the desert and after a few miles of 100 mph plus speeds.
Old May 13, 2008 | 10:26 PM
Mez's Avatar
Mez
It has not gotten that hot in Austin yet and I was driving normally at highway speeds. But anyway, the point I was trying to make was I thought they felt a little soft at low pressure, so I upped the pressure a little. Just personal preference.
Old May 14, 2008 | 02:13 AM
kfox's Avatar
kfox
Last month I was traveling across the Arizona desert and I noticed my DIC display said "Tire pressure in rear left tire is too high". I checked it out and it was at 41 and the rest were at 39. I had just recently set them all at 36. I got out and let some air out of that tire and the message went away. I thought that was a pretty cool safety feature that alot of other cars don't have or know about until it's too late and they have a blowout. Sorry for getting off the original subject.
Old May 15, 2008 | 12:40 AM
71stang99's Avatar
71stang99
I have had just the opposite happen, I had to work in Reno and the tire pressure was fine in southern Nevada but the temp was around freezing in northern Nevada at 0600 so the DIC was stating low tire pressure.
To New Tires??
