What's the deal with the gas pump shutting off before the tank is full? I've heard of this random problem, but never heard of a solution. Occasionally, I'm unable to fill the tank. No rhyme or reason. Any ideas?
It was a problem until I tuned it sideways while pumping gas. It fixed the issue. Good Luck!
Turn the pump handle to the 3:00 or 9:00 position, and it should click off when full. DO NOT attempt to top off! It will end up running down the fender.
Wow is this ever true....when mine clicks off, it will not take 10 cents more gas. I imagine it would be much more difficult with the big emissions gas nozzles in Calif!
