Active handling problem
Old May 14, 2008 | 07:26 AM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
Default Active handling problem
It started Sunday. (My 08 A6) I came to a stop and the brakes locked up, would not let me go. I put in reverse and finally backed up about 5 feet and and then put in foward and finally let go. It happens every time I stop and I can hear the rear brakes rubbing. My active handling flashed in the dic. I understand there is a service bulletin out. Has anyone else had this problem? My car is serious modded and I hope they fix this under warranty.
Old May 14, 2008 | 08:12 AM
dennis50nj's Avatar
dennis50nj
Paul if it does it everytime you stop, try pulling the fuse under the hood. i pulled it when i first got mine to try and beat the TM. but i couldnt heat the tires with it out
Old May 14, 2008 | 08:25 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
or see if 'all off' mode helps. hold the t/c button until the a/h t/c disabled message appears. (about 5 seconds).
Old May 14, 2008 | 08:51 AM
patton's Avatar
patton
St. Jude Donor '09
you need to scan the ABS module for codes and check brake basics eg caliphers sticking
To Active handling problem
