Bought a Vararam - should I be afraid?
Old May 16, 2008 | 05:15 PM
FZovko's Avatar
FZovko
Default Bought a Vararam - should I be afraid?
I bought a Vararam for my new 2008 LS3/Z51. I was planning on cutting the shroud in place. Should I be afraid?
I'm pretty good mechanically but pretty nervous about the surgery. Tips and advice would be appreciated
Old May 16, 2008 | 05:24 PM
runutzzzzz's Avatar
runutzzzzz
I don't remember which CAI it was but one of em if you are not careful you can ruin your condenser.
Old May 16, 2008 | 05:29 PM
punky's Avatar
punky
Banned Scam/Spammer
Hi neighbor! Just noticed that you are in Jefferson. I live there also and just bought an 08 about a week ago. Been wrenching for many years as a hoby and have done just about everything. I'd be glad to give you a hand with the install, got tons of tools. I'm considering a Vararam and a tune myself. PM sent.
Old May 16, 2008 | 05:35 PM
StoplightWarrior's Avatar
StoplightWarrior
I'm in the same boat...I'm totally fine with doing bolt-ons to cars, but this cutting thing has me worried. That, and the directions for the shroud are quite vague. Is there a good writeup with pics on the net for the ls3 install with cutting??
Old May 16, 2008 | 05:59 PM
SANJU100's Avatar
SANJU100
ok, learn from me. i made a hole in my condenser and had to pay a lot to get it fixed. but it was 100% my fault. here are the tips:
1. don't get frustrated.
2. take your time cutting the shroud with the blade.
3. control your hand and be focused at all times. don't think about a nice cold beer or a hot girl.
4. read this post http://forums.corvetteforum.com/show...8&forum_id=101
you will do just fine. its very easy to install. just be careful with your "hand control" as you don't want to mess up the condenser.
danl72's Avatar
danl72
To help make sure you don't cut the condenser, put something, cardboard, etc between the shroud and the condenser. If you hit anything it won't be the condenser.
Old May 16, 2008 | 06:03 PM
SpeedFreak81's Avatar
SpeedFreak81
pics don't show up.
Old May 16, 2008 | 06:48 PM
StoplightWarrior
Yea, that would be perfect, but the pics are gone any other links???
Old May 16, 2008 | 06:54 PM
SANJU100's Avatar
SANJU100
ooops, the pics used to show up. i think its your computer. i cannot see them when i am at work, but when i am home, i can.
Old May 16, 2008 | 07:01 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Originally Posted by danl72
To help make sure you don't cut the condenser, put something, cardboard, etc between the shroud and the condenser. It you hit anything it won't be the condenser.
supposedly, it sez this in the instructions that come with it. and not shirt cardboard .... something a little more substantial such as a cut up liquor box cardboard, I'd suggest.
Old May 16, 2008 | 07:36 PM
SeanMo's Avatar
SeanMo
St. Jude Donor '10-'11
I heard of people using a cookie sheet for added saftey and a razor blade should cut the shroud. I think Im going to do mine tommorow.
Old May 16, 2008 | 07:38 PM
StoplightWarrior
that's cause the pics are still stored in your cache/temp folder. They're off the net for the new viewers, though.
This might be a pita for you, so no worries if you can't, but if you want to click/save target as, and repost them, I know many of us would appreciate it!
Old May 16, 2008 | 10:52 PM
Redeemd's Avatar
Redeemd
3rd Gear
Once you get the cut started, use a heavy-duty shears. I used a tin-snips. it worked great. This was after I nicked the condenser. $600 mistake.
Old May 16, 2008 | 11:10 PM
goatts's Avatar
goatts
Don't use cardboard! Get something your razor knife won't punch through if you slip. A thin piece of plywood or plexiglass will work. Take your time. You'll need to trim several times. Cut the hole small and trim to fit. I put the whole unit together and kept laying it in the car until the fit was what I wanted.
LS1LT1's Avatar
LS1LT1
Yes...of going TOO FAST now!
Old May 16, 2008 | 11:16 PM
goatts's Avatar
goatts
Shroud is soft. Razor knife works fine. Cookie sheet is good as long as the knife won't punch thru if you slip. Take your time. You read stuff here on the forum by guys bragging how fast they did the install. Don't rush it that's how you screw up.
Old May 16, 2008 | 11:18 PM
goatts's Avatar
goatts
http://www.vetteweb.com/tech/vemp_07...kit/index.html
To Bought a Vararam - should I be afraid?
Old May 17, 2008 | 03:19 AM
StoplightWarrior
thanks!
Old May 17, 2008 | 03:57 AM
XvettemanX's Avatar
XvettemanX
put something metal between shroud and condenser, saves you alot of heartache....i used the front plate that the state of texas issued.
Old May 17, 2008 | 10:29 PM
jmt1669's Avatar
jmt1669
St. Jude Donor '11
I went to Home Depot and bought a piece of large sheet metal for less than $5.00 before installing mine. I simply slipped it down over the condenser and had no issues. Just take your time. Remember check twice cut once.
