Tpms Help
Old May 18, 2008 | 08:42 PM
C06's Avatar
C06
Default Tpms Help
Can anyone tell me if I put c-6 wheels W/ the tire pressure monitors from the C-6 on a 2002 C-5. Will the monitors work.
Old May 18, 2008 | 09:00 PM
BEZ06's Avatar
BEZ06
Nope - won't work.
The 1997 to 2000 C5 used one model sensor, and the 2001 to 2004 C5 used a different model, and you have to have the correct C5 sensor for the year you're putting it on.
When the C6 came out it used a different sensor than the C5, so C5 sensors won't work on a C6 and C6 sensors won't work on a C5.
Bob
Old May 18, 2008 | 09:19 PM
C06's Avatar
C06
Originally Posted by BEZ06
Nope - won't work.
Bob
Thanks Bob, Will the C-5 sensor fit the C-6 wheel
Old May 18, 2008 | 09:29 PM
BEZ06's Avatar
BEZ06
Yep - they'll fit right in the valve stem hole with no problem.
Bob
Old May 18, 2008 | 09:49 PM
C06's Avatar
C06
Bob
Hey Bob;
Thanks again. It's nice to get good info when you need it.
To Tpms Help
